Question about Electrolux Vacuums
How to dismantle Electrolux turbo active pick-up system foot
Screws removed from turbo active pick-up system foot, but still won't come apart
2 Suggested Answers
SOURCE: How do I replace the motor brushes in my DC11?
You can buy brushes but if the armature is overheating changing the brushes wont help
Posted on Dec 13, 2009
I need a you tube showing me how to replace the handle release. when I pick up the vacuum by the handle the vacuum head flops down
If you remove three screws you can remove the assembly with the foot pedal. Look at how it is installed closely in the assembly, including the spring, shaft and pedal. Disassemble it and install a new foot pedal exactly the same way you took it apart.
Feb 15, 2016 | Riccar 8000, 8900 Series Metal Agitator...
My pet wash bissell shampoor won't pick up the water
Hey Deanne!I know how frustrating it is not having suction when you need it.
Here's a quick link to troubleshooting steps to assist you with the suction.
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 23, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Dyson DC08 turbo brush won't turn but have suction in tube
Hi Cathy,
I'm sorry to hear you're having difficulties with your DC08's turbo brush. As you've already checked the machine for blockages and washed the filter, I'd encourage you to get in touch with us directly so we can provide further assistance to help resolve this.
You can call us on 0800 298 0298 - our UK Helpline is available from 7am until 10pm, 7 days a week. It will help if you have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 26, 2012 | Dyson DC08 Hepa Allergy Bagless Canister...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuum smells and is not picking up well. Took the pole apart and I don't know hao to open the bottom.
To get into to the bottom of the vacuum, flip it to where you can see the bottom of the baseplate. Only unscrew the recessed screws...4 to 5 screws. Once you have removed those, the basepalte will pop off. It is probably just clogged at the bottom.
Sep 05, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I have a Bissell 2x Turbo 9300 shampooer. It won' spray from the carpet/floor position. I re-booted it and checked for blockage - nothing. I flushed the hand attachment and got it to spray some...
The heater is glogged trust me. It is the size of a dollar bill with seven screws. take it apart and clean the water path also take a small drill bit to the ports of the heater.
May 31, 2011 | Vacuums
Does the turbo nozzel come apart to repair?
Hi, yes, the turbo nozzle can be broken down with just a little time and effort. The two plastic wheels in the rear pop out, and then you'll see 6 screws on the bottom of the unit. Once these have been removed, gently pry the top and bottom pieces of the turbo nozzle apart, and you'll have access to the belt, gears, and brush inside. Good luck!
If this solution was helpful, please consider rating it. Thank you!
Sep 08, 2010 | Electrolux Harmony Canister Vacuum -...
Vacuums Logo
118 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
