MY WIRELESS REAR SPEAKERS WONT WORK BH9520TW THE UNIT IS 4 DAYS OLD NOT HAPPY
MY WIRELESS REAR SPEAKERS WONT WORK,FOLLOWED ALL INSTRUCTIONS NOTHING SEEMS TO WORK,PUSHED THE STOP BUTTON AND MUTE BUTTON TOGETHER REMATE CAME UP BUT DIDNT CONNECT PLEASE HELP
SOURCE: Can't get sound from the wireless subwoofer
I had the same problem and it turned out that the directions are very unclear. You need to not only press the ID/SET button on the wireless system, but also on the wireless subwoofer itself. That solved my problem.
Posted on Oct 04, 2007
  • 93 Answers
SOURCE: wireless speakers
You should have two pieces for your wireless rear speakers setup. A. a wireless card inserted behind the all in one receiver. B. the receiving box that will connect to the 2 rear speakers.Also,you should not have any obstacles to block off the line of site for the rear speaker receiving box to the wireless card.
Best way to test it is too simply leave the rear speakers connected to the rear speakers receiving box on the floor near the a/v receiver with dvd player built in.Play a dvd and see if you have sound coming out from the rear.
solutiondoct
Posted on Nov 06, 2008
SOURCE: SC-BT !00 Panasonic wireless speaker connection won't link
If you go into the set up menu and go to the speakers set up - it only shows the right, left, centre and subwoofer on the screen. You need to go down to the box below these speakers and activate the rear speakers which are not shown. The wireless section will then light up w1/2 on the display at the front of the scbt100 - i had to call panasonic to figure this out and they advised me it was missing from the instructions!!!
Posted on Mar 07, 2009
SOURCE: my main unit will not connect to the rear unit
I had a similar problem but mine cut out intermittently.
First, check to make sure the speakers are plugged in solidly. I was plugged into an outlet with a fancy cover and it caused the connection to short out intermittently.
2. Make sure all your wires are securely attached to the receiver unit.
3. If that doesn't work, try turning off the wirless speakers and the Home Theater system and then turn on both of them.
If one of these doesn't work, Samsung has chat support available onlline.
Good Luck!
Posted on Mar 13, 2009
SOURCE: LG wireless dvd reciever system
Hi, I had the same problem, it seems to be a design error of LG or a typical problem with some component in the wireless transmitter. It is basically caused by the transmitter heating up, leading to a clock drift with the result of the receiver losing the signal. I tried to cool the transmitter in the fridge before using so it will run for about half an hour before producing this error (depends on the room temperature as well). My solution is to remove the plastic case of the transmitter unit and place it in a cool place where it does not catch heat from other devices. Without the case it does not overheat and also takes less space, just be careful if you have children. I placed the naked Tx unit behind the TV so it does not matter. Hope this works for you as well.
Posted on Aug 31, 2009
Home theater player power button is blinking and I cannot turn it ON and off
Unplug it and then plug it back in and see if it still does this. If it does then there is a problem with the power supply in the unit.
Oct 07, 2013 | LG Bh9520tw 4 Ta9.1 Channel 3D Sound BRay...
Wireless rear module won't link
samsung wireless works with blue tooth try by replacing batteries from wireless module
Jun 03, 2010 | Samsung HT-WX70 Theater System
I bought a new Samsung home theatre system with wireless rear speakers and followed the directions to hook them up, but the reciever flashes rear check. this has been going on for 4 hours
HI,
SPEAKER SYSTEM HAS TWO MAIN UNITS ONE IS ADD ON UNIT AND INTEGRATED WIRELESS SYSTEM.TRY TO MATCH THE POWER HANDLING OF ADAPTER WITH THAT ON YOUR REAR SPEAKER OUTPUT.
TNKS RABBANEES
Nov 04, 2009 | Audio Players & Recorders
Logitech Z-5450 5.1 surround sound speakers - no sound from rear right only
Unfortunately I have the same problem. As an electronic engineer I suspect that the power supply part of the unit is damaged. I opened up the module (don' t try it, its a little bit tricky since there is a type of glue around the silver bezel, after you remove the 4 screws from the front holes) and did some quick static measurements with a multimeter, so far no luck. Since I am still in warranty I will try to replace the item. Hint: protect your electronic equipment with ups or surge protection devices.
May 30, 2009 | Logitech Z-5450 Computer Speakers
Rear speakers do not work
Either the balance is off on the head unit, or the the out puts (in the head unit) for the rear speakers are blown.
May 15, 2009 | 2002 Mazda 626
Feb 23, 2009 | Panasonic SC-BT100 Theater System
Wireless speakers
solutiondoct
Nov 01, 2008 | Panasonic Home Theater System System
Rear Wirelss speaker do not work
With the main unit turned off, press and hold [REMAIN] on the home theater's remote for 4 seconds. (The REMAIN button is directly under the 7 button). Once held down for 4 seconds, the Volume Indicator on the main unit will turn on for 1 second. Release the [REMAIN].
Press the [RESET] on the back of the Wireless Receiver 2-3 times. The Standby/On LED on the front of the Wireless Receiver will blink 3 times
Turn on the main unit. The Link LED on the wireless receiver will light up if process is done correctly. The front of the main unit will no longer say REAR CHK and the rear speakers should now function correctly.
Feb 24, 2008 | Samsung HT-WX70 Theater System
2 channels not working on 4 channel amp
Well firstly are you using a parametric crossover with your radio and how much rca cables do you have coming you head unit (car radio) if you going to bridge the front up with you rear speakers u wont be able 2 hear the rear speakers try hookinking it up 2 your head unit's front speaker output and have ur rca cable connected to your amp running on your rear output of your head unit by doing this you can use your fader on your head unit to control your front and rear speakers
Nov 07, 2007 | Rockford Fosgate Punch 300X Car Audio...
20 people viewed this question
 Grubhead
Grubhead
