Question about Yamaha RX-V673
Yamaha v473 wii no video
Wii no video
5 Suggested Answers
  • 121 Answers
SOURCE: Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Posted on Feb 27, 2009
SOURCE: no picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Posted on Apr 27, 2009
MNfisherman
  • 11896 Answers
SOURCE: Tried to hook up a Wii to a Yamaha receiver and it
It is very possible the S cable is giving you problems. Is the receiver on the right input channel? Have you tried RCA's instead?
Posted on Dec 25, 2009
SOURCE: Set up Wii with my
I had the same problem and found you have to connect the yellow video cable directly to the TV. Am finding that the component cables plugged into the receiver are not delivering video through the HDMI out to the TV.
I have the same problem with plugging in a video camera to the V-Aux on the front of the receiver and still havent figured out how get the video to show up on the TV, so if you find something else out please post.
Posted on Jan 09, 2011
My yamaha rx-v473 wont turn on
disconnect all wires from behind unit, speakers, input, and then try to power it up ,
if problem persist then try to tighten screws on back panel of the unit,
may sound silly but if amp board does not have good ground connection it can do that , go in protect mode .
happened to me ...
Jan 26, 2013 | Yamaha RX-V473 A/V Receiver Black
Yamaha rx v473 system cuts off periodically - check speaker wires message comes on
You have a short in a speaker or speaker wire, or you are over-driving a speaker.
Jan 14, 2013 | Yamaha Audio Players & Recorders
Yamaha rx v473 cuts off
disconnect all speakers, turn it on. If it stays on, connect one pair of speakers at a time and when it shuts off, that speaker is the problem. There may be a short in the wire or the speaker may be bad. If you get that far, try connecting the bad speaker with another speakers wires.
Jan 14, 2013 | Yamaha RX-V473 A/V Receiver Black
I can't get video out to TV from Wii video input on receiver. Wii is connected to AV5. Video to TV is thru HDMI out on receiver to HDMI in on TV. I can port the audio but get no video
Hello there,
ok the setup you are using is a Receiver, TV, and Wii unit .
Step 1: plug one HDMI cable into the back of the Receiver unit on slot 2 name on it is called HDMI out jack
if looking at the back of the unit this slot is 2nd from the top left
Step 2: now plug the HDMI cable into the TV this is the cable you just plugged into the Receiver
TV done
Step 3: Wii Setup move the Yellow,White,Red cables over to the right if looking at the back of the unit 2 spots name for this group is called AV out Jacks .
Wii Done
now use the right input channel for this group and you should now See Wii playing .
Thank you and don't forget to Rate
Jan 26, 2011 | Yamaha RXV467 Receiver
Yamaha Receiver RX-V367. Connected a WII to the audio/video jacks in front. Sound but no audio Do I need to select a certain device from input menu?
I am trying to connect my Wii with the component cables to my yamaha rx-v367. No video but sound. What am I doing wrong?
Jun 19, 2010 | Audio Players & Recorders
My wii won't play video through my Yamaha RX-V465. The audio comes through OK. I have a normal signal video component cable and i have connected the receiver to the TV with a HDMI cable. i have tried...
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
May 09, 2010 | Yamaha HTR-5840 Receiver
Dec 25, 2009 | Yamaha RX-V520
No picture from wii
Cheers
BJ
Mar 19, 2009 | Yamaha RX-V800 Receiver
Feb 25, 2009 | Yamaha HTR-5760 Receiver
I have the Rx-V661 and I just got the WII. I input the WII into the Video AUX on the front panel and pressed the aux button on the remote and nothign happened.
Just a thought, but, how do you have your TV/Monitor hooked up to the Yamaha unit? If your only connection between the receiver the and the TV/Monitor is an HDMI cable, and you are plugging your WII into the front v-aux jack using composite video, the receiver will have no way to send the video signal to the TV/Monitor. The receiver upconverts all composite video and S-video signals to component video signals. This means that if you only have an HDMI connection between the receiver and the TV/Monitor, you will also need to establish a second, component video connection between the receiver and TV/Monitor to handle the upconverted WII video signal. You will probably also need to switch your TV/Monitor to use that input when you are using the WII.
Of course, if you already knew this and have it set up that way, this answer won't help you at all!
Dec 25, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V673 Logo
242 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
