I need to be able to use the entire channel selector.
I need to attach a digital box to this television. The box needs the tuner to be set at a particular channel. The channel selector switch on the tv bypasses that channel. How do I unprogram the channel selector so that I may tune it to the needed channel?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A couple of possibilities:
  • on the remote press the channel number;
  • in the MENU/SETTINGS, add that channel to the memory;
  • in some models/version of the digital receiver box, there is a selector switch at the back between 2 channels for the RF output.
Additionally, post back the brand and model number that we can figure out more detailed steps should it be necessary.
Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 18, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! On My Combo, I went into the Channel settings and Manually Set the Channel . Also on some models you can have it set to When you Push Input it will go automatically. My 36 inch did this Automatically with no setting Changed.
    Genius:
  • 1,913 Answers
Reset your all settings to factory defaults.
check there is any reset button on box back side .press it for 10 seconds if not then press power button for 10 seconds.
also u can reset alllsettings in menu
  • kishor khatri
    kishor khatri Jan 21, 2009
    reattch all connection
Using a digital antenna to channel scan for broadcasted channels
It is no different that channel scanning for cable or analog over-the-air channels. You simply ensure that you have selected the digital tuner of the set prior to scanning. Some older flat panel sets do not have integrated digital tuners. A digital antenna alone will not allow these sets to receive digital broadcast channels. A converter box is needed to convert the digital broadcast signals to analog for the tuner in the set. Also, sets that do not have digital tuners may not support the resolution rate of digital TV broadcasts. Most digital HD broadcasts are 720p and a few are 1080p.
Jul 28, 2016 | Televison & Video
What settings do my Samsung tv need to be on to link a digital cable box
The digital cable box will most likely connect via an HDMI connection. Simply ensure that the SOURCE selection for the set matches up to the HDMI port that the digital box is attached to. There is no need for any kind of channel scan when using this type of connection as the cable box acts as the digital tuner. If you are coming into the set on the coaxial cable line, then that is a different story. Ensure that the digital cable box is turned on, then do a channel scan to locate the channel that the cable box is using to send the signal.
Mar 02, 2015 | Samsung Televison & Video
Attach tv converter box
Everything is digital now. You will need a digital converter box. You will connect an antenna to it, and then connect the box to your tv. The box will come with it's own remote. Your tv will be set to channel 3 or 4 (depending on the converter box you get), and you will control the stations with the remote that came with the converter. You can get them at any electronics store.
Jan 09, 2014 | Jensen J53-BWR 5 in. Portable Television
Tv stays on one channel,no color or picture just ghost or outline, i have a Sharp lc46sb 54u
Check the settings to see if it is locked on channel 3 for external tuner source to have an input from a cable box ant in that needs 3 to function or from some other externally decoded signal like a vcr. Does the TV have a Digital tuner or the old analog tuner? If it's digital you can hook up a rabbit ear antenna with the UHF output on it & should be able to tune in some stations. If it's the old style then you will need a converter box to get it to receive any stations.
Fist check the settings to see if it has it set to lock on channel 3 for external tuner source.
Apr 03, 2013 | Sharp Aquos Televison & Video
Trying to hook up a digital antenna but no channels coming in
You need to get a connection from a local cable or wireless service with a set top box to be connected to the input. Please check with your local operator and see if the set top box is needed for the digital feed.
Otherwise you might need a dish with the LNB to be used to the TV. Digital tuner means that the tuner is working to scan and memorising the full band width of the channels with digital processing and thus faster and crisp.
Check the details of the TV from a forum:
http://reviews.cnet.com/direct-view-tvs-crt/philips-32pt9100d-32-crt/1707-6481_7-31473699.html
Oct 22, 2011 | Philips 32PT9100D 32" TV
Cant seem to tune in after digital switch over not got any chanels
If your TV is an older variety that wasnt set up for digital signal you will need a set top converter box.
Jun 22, 2011 | Toshiba Televison & Video
I have a symphonic wf32L6 and i dont want to buy a digital adapter box, doesnt this tv have a digital tuner
Yes it has a Digital Tuner/ HDTV Tuner. Go into the setup menu of the TV and do a digital channel scan. If you still have an issue, post a reply/comment and I will help you further.
Jun 01, 2011 | Televison & Video
PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Nov 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
