Question about Dell E151FPp 15" TFT LCD Flat Panel Monitor
Dim backlight thru the years my Dell 15" monitor E151Fpp s the backlight very dim at the most + brightness stand in the OSD. Is there a solution for repair/ replace a backlight lamp CCLL, and where are these lamps availeble? greatings erik blankers
5 Suggested Answers
  • 15 Answers
SOURCE: Monitor problem
It sounds as if you have a resolution set that the display does not support. Restart your machine in safe/VGA mode by holding down F8 while the machine boots. Once in safe mode, set the resolution (Right click--> properties--> Settings--> Screen Resolution) to one that your display supports.
Posted on Jun 19, 2007
tantong
  • 138 Answers
SOURCE: Dim picture
This is the way how to examine where the problem is. If the screen is going dark. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 09, 2008
  • 334 Answers
SOURCE: No display but power led is on
sounds like a video card problem in your pc. If you are using the onboard video output on your motherboard, you probably need a new one. If you are using a card that has been added to the board in a slot, try your onboard output (looks the same)
Posted on Jun 15, 2009
budmrtn
  • 11361 Answers
SOURCE: Dell E151FPp 15" TFT LCD
It does not have DVI port, only VGA.
http://support.dell.com/support/edocs/monitors/e151fpp/En/attach/attach.htm
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 18, 2010
I HAVE MONITOR DELL E151FPP, THE PROBLEM IN THE RESOLUTION WHICH IS 640 X 80 ONLY
Make sure you've downloaded the driver for your video card. As long as that is installed and it supports higher resolutions, you should be able to go to your system settings and change it (this process will depend on your operating system).
Mar 30, 2011 | Dell E151FPp 15" TFT LCD Flat Panel...
Dec 17, 2010 | Dell E151FPp 15" TFT LCD Flat Panel...
E151FPp (Gray) 15 in. Flat Panel LCD Monitor: I am not able to get DIplay Driver for my LCD moni...
The 32bit color has nothing to do with monitor driver, that the video card driver issue, it sounds like you do not have correct driver for you video card.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | Dell E151FPp 15" Flat Panel LCD Monitor
How to control the brightness of Dell TFT monitor
That's the buttonsd on the monitor, not the PC.
Press the [menu] button on th emonitor.
The screen will show the labels of the buttons now.
press the "arrow" to position to the brightness setting (the "sun" icon)
press the minus [-] button to dim
Press [Menu] to save & exit the OSD (on screen Display)
Sep 30, 2009 | Dell E193FPp 19" TFT LCD Flat Panel...
Jun 15, 2009 | Dell E151FPp 15" Flat Panel LCD Monitor
The screen has lost its brightness
Someone has probably changed the brightness settings. Increase the brightness and see if this resolves the issue. If it does not then I would assume that the monitor's backlight is a toast and you may have to install a new backlight.
Feb 15, 2009 | Dell E151FPp 15" Flat Panel LCD Monitor
Sleep mode on a dell monitor
Hold down the function key on your keyboard (lower left hand side of your keyboard between the control key and the windows key) and the F8 key simultaneously. This cycles through all monitor set up modes.
Nov 22, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
False color with Dell E151FPp and Mac Mini
a big issue with this..does the mac mini have the drivers for that monitor? only one way to find out..
www.mac.com has support and drivers, no?
Jun 16, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
Dell E151FPp 15 TFT LCD flat panel dim
Do you have the same issue when the cable is disconnected from the computer? If so, and the the brightness function doesn't change, then you have an IC Chip failure and the replacement boards are not available to you or me as Dell is Dell and everything from them is proprietary. If you are under warranty pursue that if not, time to replace. Consider this a time, unwanted time, but time to upgrade.
Oh, your right about the sacrificial diode on the power card... you wouldn't see anything.
Hope this fixed ya.
Regards,
Worldvet
May 15, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
Dell E151FPp 15" TFT LCD Flat Panel Monitor Logo
mukhtar21 shaikh
mukhtar21 shaikh
