Question about Sony Ericsson w580i Cellular Phone
Blue flashing light on Sony Ericsson w580i phone
There is this blue flasing light on my Ericsson on the buttonson the left(back button)...is there any solution??
  • SEricsson19 Jan 18, 2009
    I have a sony ericcson and on the buttons on the left there is a blue light and it wont come ooff i dont even no why its there
    Sergeant:
  • 431 Answers
Can u ask u r question clearly
Posted on Jan 18, 2009
Bluetooth not working in sony W580i phone
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
My phone blue tooth is not worked please send the solution
Make sure both your phone and bluetooth are fully charged....turn both off...turn your phone on...go to settings and tools...bluetooth menu...check to make sure your bluetooth is listed under devices....bottom left should say "turn on" press the button and it should display " bluetooth power on".
Turn on your bluetooth...in a few seconds your phone display should indicate "bluetooth connected".
Apr 24, 2009 | Sony Ericsson w580i Cellular Phone
Sony Ericsson W580i screen went blank
Ok, my phone had the same problem. I took the face plate off and the screen out and there's actually a little connector that connects to a board behind the screen(can come unplugged for replacement). I fiddled around a little with it and it worked fine. about a week or 2 later it happened again. I tried fixing it again and it would just flash white>black>lines>white, repeat. I know my phone's taken a bit of abuse, dropped down a road, soaked in rain, but it always worked after. These phone screens aren't meant to take abuse. Problem; the phone screen died. Solution; get a new screen.
Apr 20, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Sending phone book from sony ericsson w580i to bluetooth mirror
Not 100% on this, but your Sony may only work with Sony bluetooth for this. I know they do such things to promote their sales. Since the actual Bluetooth communications protocol is the same for all phones, you'll be able to pair, but you may not be able to transfer your contacts.
Nov 13, 2008 | Sony Ericsson w580i Cellular Phone
W580i Screen!
the firmware on the phone need to be flash to correct this issue...try topsony.com or take the phone to a mobile service center and have them flash it for you.
Oct 23, 2008 | Sony Ericsson W850i Cellular Phone
Unlock sony ericsson w580i
i want to unlock the phone which already locked. model sony ericsson w580i
Sep 05, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony ericsson w580i phone lock code
Open up XS++
Then connect the phone while holding "C", afterwards use the GDFS opiton to read the code wink.gif
Make sure you have USB FLASH DRIVERS INSTALLED
HOLD "C"!!!!!
AND FIND USB FLASH DRIVERS HERE !
1. Powered off the phone
2. Taken the battery OUT.
3. waited 30 seconds to a minute,
4. started XS++
5. Clicked on Connect on XS++
4. HOLDING C button
5. Connected the USB Cable,
6. waited for some time, got message no phone detected.
Tutorial VID
Let me know.
micro
Aug 16, 2008 | Cell Phones
I hav a sonyericsson w580i and my right button, walkman, and applications button does not work -
The w580's sometimes get a short in a bend in the upper switch flex. It needs to be replaced. I'd bet that the lights on the right and left side of those outer buttons are different colors. Try applying light pressure just below the LCD screen and see if it brings those buttons back. If it does, that flex is bad and needs to be replaced.
Contact www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited. They can take care of that a lot cheaper than sony ericsson can. If you can find the part on line, you have to completely disassemble the phone from the back through the front to get to that flex. Switch Flex for Sony Ericsson w580i.
Jul 31, 2008 | Sony Ericsson Cell Phones
Sony ericsson w580i
the EROM file on your phone is corrupted that is why it just flashes red and not boot-up, you need to have the EROM reflash for the phone to work again.
Jun 18, 2008 | Sony Ericsson W850i Cellular Phone
Sony Ericsson w580i Cellular Phone Logo
223 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
