Question about Canon PIXMA Office Equipment & Supplies
When do you replace ink cartridges on canon mg 5300 printer
SOURCE: Printer not printing black ink
The problem you are all having is with the print head (The black tray that your ink cartridges sit in).
Most of the time a simple cleaning of this will correct the problem, if it does not then you will have to call Kodak support and they will send you out another print head.
But lets try and see if we can get your troubled one to work again by following these steps...
1 - turn printer on and open the lid as if you were going to change the printer ink cartridges.
2- when the ink tray moves into the center and stops, remove both the black and color cartrdiges from the print head.
3- To remove the print head simply place your left thumb inside the head all the way to the left facing up and pinch the upper left lip of the print head to release it, then pull the entire tray out with your other hand ( there is a release inside the tray above the sticker of a finger and bullseye to the far left in the upper left corner inside the tray)
4- With the tray now removed be sure to look at the bottom and you most likely will find a build-up of black ink... clean this off using DRY paper towel as much as you can.
I used rubbing alcohol but if you do this make SURE it is completely dry before reinstalling.
5- Once you have cleaned the print head reinstall it in reverse fashion than you removed it, if you installed it right you will hear a solid CLICK noise.
6- replace the ink cartridges you removed if they still have ink in them and then close the printer lid.
7- You may get a notice that there is a new printer head and or cartridges and it will want to align and or calibrate the printer...be sure to do this!
8- Once the printer is recalibrated hit the menu tab on the printer and choose " clean ink head"... Do a deep cleaning 2 times!
9- Now try to print something that contains something black like a text document. If it works you are all set, if it did not then you will need a new print head from kodak. simply explain that you did the above steps and it did not work so that you can avoid support trying to run you through all this. They will send you a new one in 2 days.
Hope this helps and good luck!
Posted on Sep 04, 2008
Josue Pongco
  • 154 Answers
SOURCE: Kodak 5300 shows
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Posted on Sep 23, 2009
Testimonial: "I will give it a shot when I get home..Thanks.."
  • 191 Answers
SOURCE: Reset Canon printer chip
you can override ink check status and manually reset it in drivers options
Posted on Sep 22, 2009
manuel-d
  • 5 Answers
SOURCE: Canon Pixma ip1900 Printer wont print
i think you need a canon resetter just download it and it will fix your problem. gud luck ellyhill
Posted on Nov 16, 2009
nblady
  • 206 Answers
SOURCE: HOW DO I REPLACE MY INK CARTRIDGE IN MY CANON 2600 PRINTER?
How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Good luck
Posted on Feb 15, 2010
I changed the ink cartridges, and now it won't print, it prints manually but not from the computer, it says there is no ink but the cartridges are new
You most likely are using aftermarket or refilled cartridges. These will normally not register as full. Here is a link to a procedure that should solve issue. Watch the video and follow the instructions....
Canon 240 241 Cartridge Ink Level Reset Procedure Pixma MG MX Printers
Jun 24, 2016 | Canon PIXMA MX472 WIRELESS OFFICE...
No ink on print out from canon mg6150, please help
how much ink is in the ink Cartridges?
have you changed the ink cartridge recently ?
You may need to clean the print head.
see http://www.cityinkexpress.co.uk/cheap-printer-cartridges/canon/pixma-mg6150/mg-series/cleaner/printhead-cleaning-cartridge/yellow
http://www.ebay.com.au/itm/Printhead-Ink-CLEANING-KIT-Fix-Canon-PIXMA-MP990-MG6150-MG6250-QY6-0078-000-New-/250992770857
seems to look like it may be a manual procedure with the mg6150 rather than a computer setting in the printer properties. Look under properties to see if there is a computer generated head clean .
Feb 24, 2015 | Canon Office Equipment & Supplies
"How do you reset the ink on your Canon MG 3200 printer when you have the cartridge"
Hi, its possible the cartridge nozzle was damaged on refil, or theres ink residue on the sensors, please be careful when cleaning with a soft cloth
Jun 21, 2014 | Canon PIXMA MG3220 Wireless InkJet MFC...
My canon mg6150 with a CISS has crashed have now purched a mg-7160 will my CISS fit the mg-7160
Hi, My name is Liam from rihac, although we do not sell printers I work very closely with them via our inklink products. The MG6150 uses the older 525/526 series cartridges and ink. You will not be able to reuse the older CISS you have in the new MG7160 without replacing cartridges, chips and ink.
Nov 26, 2013 | Office Equipment & Supplies
How do I reset Canon MG 4170 ink level
I have not used your particular model of printer or these specific cartridges, but the UK versions of these cartridges cannot have the ink level estimate reset. However it is not necessary to do so to continue using these cartridges.
Instead when the cartridge believes it is empty the printer will ask for a prompt from you in order to continue printing (usually in a rather lengthy message). We made a short video on the subject:
Jun 08, 2012 | Canon PIXMA Office Equipment & Supplies
Error code 16
Hi there .the error e1.6 on Canon Multifuntionals ( MP, MG , MX ) is :
DESCRIPTION:
Ink has run out.
SOLUTION:
Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed.
Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing.
The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
I hope this information will help you
Dec 22, 2011 | Canon Office Equipment & Supplies
Changing individual ink cartridges for Canon MG 6120 Pixma wireless color/black and white printer
Go to the following link and click on service and support.
http://usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/ pixma_mg6120#ServiceAndSupport
In enter question box enter your question i.e. How to replace the individual cartridges. You will get detailed instructions incl a video.
Oct 16, 2011 | Office Equipment & Supplies
The color ink cartridge that is " blinking " is
Don't buy Canon as they absolutely ROB you for the ink!! They are worse than ****** dealers! At least HP allows you to use non (rip-off) OEM cartridges without all the hassle! My printer will be thrown out after the ink runs out as I will not be ripped-off by Canon again!
Apr 30, 2011 | Canon Pixma MG5220 InkJet Printer
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My kodak 5300 will not accept the new ink cartridges
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
1,204 people viewed this question
old marine
old marine
