Question about SanDisk Sansa e260 MP3 Player
Fast forwarding through ebook
I want to fast foward through my ebook but when I push the fast forward button it will only go for a few minutes and stop. What's up?
  • 8,596 Answers
Ebook files are so long that pressing FF for an extended period of time overheats the player.
Posted on May 23, 2008
SOURCE:
Trying to set my clock on my jvc kd lh 2000 but cant same to find out how
Press the Sel button (the center of the control ring) for more than 2 seconds until a PSM control category appears in the display. Use the up/down arrows to navigate to Clock. Then press the fast forward or fast reverse button to select Clock Hr. Then turn the control knob clockwise to add to the current value or counterclockwise to decrease the value to the desired hour. Then use the fast forward or fast reverse to select Clock Min. Repeat turning the control knob to set the Minutes. Press Select again to save the setting.
The manual is here: http://books.jvc.com/booklist.asp?Model=KD-LH2000 . The clock set procedure is on page 29.
I hope this helps.
(In a few cars, I've seen the controls end up reversed. If it doesn't respond as above, try swapping the order of the up/down and fast forward/reverse buttons to navigate the menu properly.)
Nov 22, 2010 | JVC KD-LH2000 CD Player
How do I cahge time on french tank
  1. click the top button to stop the second hand
  2. click the bottom button to reset the timer
  3. pull the crown out all the way
  4. twist the crown forward hard and fast for a few seconds. The minute hand will start advancing very quickly.
  5. when the desired date and time is reached, push the crown back in place. If you missed the time, pull the crown back out and twist backwards. The minute hand will move slowly in reverse. If you twist hard and fast, the minute hand will start spinning in reverse again.
Jan 16, 2010 | Cartier Tank Francaise W51001Q3 Wrist...
Stanley 10-788 how to change blade
Push the top metal button all the way foward as if pushing the blade out to it's (farthest) 3rd setting. Then push foward and down one more time which locks the mechanism down. Push and hold the yellow side button as you insert the blade. When the blade locks in all you have to do is release the yellow button and return the top slide to it is fully retracted home. The blade is loaded
Jan 14, 2010 | Hand Tools
My remote control cannot work on rewind, fast forward or comerical skip. The DVD screen display SET 1.
Hello, I had the same problem and after spending a few hours reading and trying things, I found a solution. Its very simple. Power on your unit (manually) and then on your remote control push and hold at the same time"enter" and the number "1" while pointing directly to your unit and this should solve the problem. Good luck.
May 16, 2009 | Panasonic DMRES15 DVD Recorder
Driver side car seat
The seat may be too far forward, and when it is at the forward limits, the seat sticks. I get in the seat, and I press the back button whilst pushing hard with my feet against the floor.
Aug 14, 2008 | 1996 Toyota Avalon
Fast forward of Disk on my Go.Video2140
Try keeping pressed the skip button to do fast forward on a Disc.
Apr 22, 2008 | GoVideo Go Video DVD/VCR Combo
Jvc kd-g200 cd player
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=260a73e6d269444e666771376ad18c85&q=JVC+KD-G200
Type in the code shown at the bottom.
Click "download now"
Click where it says "link" in blue.
Click "save"
Save the pdf to your computer's hard drive.
Instructions are as follows:
Press and hold the "select" button for more than 2 seconds.
Press the "fast forward" icon button.
Turn the dial to appropriate hour.
Turn the dial to appropriate minutes.
Press the select button.
Apr 17, 2008 | JVC KD-G200 CD Player
When we Fast Forward or Rewind the screen turns blue
try to not fast foward and see what happens
Apr 15, 2008 | Televison & Video
PARENTAL CONTROL
The password to the parental control is using the Fast Forward and Rewind buttons, it is forward, back, forward, back.
Mar 03, 2008 | Starlite HM600D DVD Player
SanDisk Sansa e260 MP3 Player Logo
131 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
