Question about Kenmore 44042 Front Load Washer
Kenmore 417.44142400 front load washer load noise in drum area..!!!
Replaced the shocks at bottm of drum...doesnt suck water out properly and little shavings of plastic on clothing and loud noise!!!
SOURCE: kenmore Front load washer model
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Posted on Aug 30, 2008
  • 8 Answers
SOURCE: Banging and loud howling noise at high speed
Drum bearings may have given up.
Posted on Mar 13, 2009
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
Karthik316
  • 187 Answers
SOURCE: loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Posted on May 22, 2009
  • 20 Answers
SOURCE: replacing shocks on front load washer
through the lower door panel in front of machine. Why???? is machine walking , bouncing or other wise?? This machine spins at HIGH Rpm's so most usual problem is one leg maybe unlevel or possible wood floor maybe "giving " as machine spins and allowing the machine to walk...but then again if machine is "old" shocks could be worn out
I have a Kenmore [2005]front load washer that vibrates severely when in high spin and is quite noisy. I have had the top panel, back panel, and bottom front kick panels off and I can not find any obvious...
you may need to change the bearing on the drum easy way to check is while the door is open try to manually spin it with your hand if you hear a grinding sound then the bearing is gone
Nov 05, 2010 | Kenmore 44102 Front Load Washer
Drum is loose moving back & forth, water leaks & water do not drain from drum
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Drum appears to float and move up and down very easily, top pary of stainless steel drum seems exposed behind teh rubber gasket
heatman101
Sep 06, 2010 | Kenmore 43042 Front Load Washer
It seems that the drum is spinning off its axis
When a front load washer does not spin properly, the problem can be caused by failed axle that connects the pulley to the wash drum, or failed shock or (possibly) broken suspension springs.
Remove washer top, inspect the two or four springs holding the washer drum up. The whole drum should be able to "bounce" a little, when you press down on it.
Remove the lower front panel and with a flashlight, inspect the two shock absorbers. Both should attach up to the wash drum, but it is common for them to break, especially if the front load washer has been moved from one house to another without re-installing the lower brackets and the long bolts that secure the drum during the move.
If the springs and shocks are not damaged, with the top removed look down into the rear area. You will see a large pulley with a belt on it. If you see brown/black grease marks all over or obvious problem when you try to turn the pulley, you have found the major problem.
Please get back to me with what you find. OK?
Jan 03, 2010 | Hotpoint WMA58 Front Load Washer
Rubbing noise on front load washer drum
dont they have 4 shocks?
the drum is imbalanced i would wager
Aug 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
May 22, 2009 | Kenmore Washing Machines
Broken shock absorbers on front loading Kenmore
Hi, first things first. Your model and serial numbers should be on a sticker somewhere around the door opening. Next check the tub. With your finger,push up on the rim of the tub then rotate the tub a few inches and push up again. Continue through a whole rotation. If the tub moves and make a clicking noise you have a bad drum bearing and the cost to repair is more than the unit is worth. If that's not an issue,then it's probably just the shocks,replacing them should solve the problem. Hope that helps.
Mar 21, 2017 | Kenmore Elite 45986 Front Load Washer
Kenmore spin cycle thumping noises
I just went through the same issue with my Kenmore front loading washing machine. I assumed (and a Sears repairman also told me) that it is the bearings. After I took the drum assembly out, I saw the rear drum broken and the inner tub hitting the outer tub. I ordered the outer drum assembly and only when I took the inner drum assembly out I realized the the "Spider" attached to the inner drum (and spindle) was broken. Entire drum assembly cost $417 + shipping and it may be cheaper in the long run to buy a new washer. I like the front loaders because they save water and good for the environment, but the US manufacturers have not yet perfected the technology like European manufacturers (or they don't want the machines to last too long just like cars). Anyway, I am looking into welding the spider tomorrow. If not will return the outer tub assembly and buy a top loading washer for $300!
Dec 07, 2006 | Kenmore 44102 Front Load Washer
Kenmore 44042 Front Load Washer Logo
104 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
