Question about Frigidaire ATF6000ES Front Load Washer
My Frigidaire washing machine is stuck on "sensing". It will not continue with wash cycle.
I ran a cleaning cycle before it prompted me because I felt the washer needed it. After running the cleaning cycle, I usually do a rinse and spin because I learned the hard way that some of the bleach stays in the bin. I know have tie-dyed sheets! The rinse and spin cycle never completed. It was stuck on "drain" for over a day. I tried to do a load of towels and my machine is now stuck on "sensing". I have tried doing different cycles, letting the machine sit with the door open, etc.
Master_Tech
  • 770 Answers
SOURCE: washing machine error code on Frigidaire ATF6000E
No E20 on that model# Heremis a list of the codes
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E52 Bad signal from tacho generator. Refer to test (8)
E56 Highmotor current. Refer to test (9)
E57 High current on inverter. Refer to test (9)
E58 High current on motor phase. Refer to test (9)
E59 No tacho signal for 3 seconds. Refer to test (10)
E5A High temperature on heat sink. Test first if bad replace
speed control board.
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E75 Water temperature sensor circuit. Refer to test (12)
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
Posted on Apr 01, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
huuum
  • 750 Answers
SOURCE: frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Posted on Dec 05, 2008
rylee_smith
  • 8619 Answers
SOURCE: Frigidaire FWS833AS1 - My washing machine recently
Hi
Thanks for using FixYa. The smell might be due to burning of lid switch. If the washer isn't spinning then it might be dueto a Lid switch or due to a bad motor coupler. You can check for the lid switch& replace it--
First unplug the washing machine. Then remove the two screws that hold the top consolein place; these are located in back of the main console (where the dials are).Once removed, the entire console swivels back, exposing the wiresunderneath.
After this unplug the wiring harness that is connected to the washing machinetop flat surface. Now remove the two s-shaped brackets with a screwdriver byprying underneath. This will allow you to remove the main sheet metal framearound the washing machine. The lid switch assembly is located under the topconsole. Now, remove it and replace with the new assembly and put it backtogether.
Please look this schematicfor lid switch location(part # 50)--
You can buy the lid switch from this link--
Frigidaire FWS833AS1 Lid switch/assembly
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 16, 2009
SOURCE: My washing machine gets stuck after rinse cycle
Before spending any money calling a repairman or changing parts, check the drain hose. If it is too deep down into the drain pipe then pull it back so that only about 6 to 10 inches is down the pipe. If it is too far down then it creates a vacuum which drains the water as it is trying to fill for the final rinse.
Posted on Mar 05, 2011
Stuck on washing cycle
Thank you for your post, Patrick Chow!
From my understanding your Frigidaire dishwasher is getting stuck in the washing cycle. Sounds like you may have a possible issue with a sensor or control panel. I would suggest performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for approximately ten minutes. If you continue to experience problems with you dishwasher not cycling I would recommend reaching out to a technician for a diagnosis to be completed. The technician would be able to pinpoint the cause of the failure and complete repairs. Hope this is helpful. -Matt
Nov 17, 2014 | Frigidaire Washing Machines
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
Water overflowing and never shuts off
Jammed solonoid valve open position.....
Nov 02, 2009 | Frigidaire FWS1233F
Mold and mildew in door. washed, cleaned, ran
the only thing you can do now is replaced the door boot seal. after replacement usually you have to leave the door open till completely dry or dy it with a towel after each wash
Sep 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Matayg Atlantis Washing Machine gets stuck in the Rinse Cycle and will continue to rinse for hours.
This is the sign of a bad timer. It is not sensing how long it has been in the cycle. The timer is not advancing. Replace the timer.
Feb 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Sensing light comes on and then the timer stop going down
I do nto have a solution- just the exact same problem. My machine gets stuck on 76 when doing a "normal wash" . last night I hit cancel and drain, then went to "time saver" and ran the wash and it seemed to work fine. Funny that both of our amchines stop at 76. Any ideas?
Nov 18, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Water continues to fill machine but the wash cycle never begins
The pressure switch is stuck and not sensing the correct amount of water
Aug 04, 2008 | Washing Machines
Display panel
Check to see if any water remains in the machine . SOME MACHINES IF They DO NOT DRAIN OUT ALL THE WATER WILL CONTINUE TO run until all water is drained. Also check for suds in machine if machine senses suds it will try to re rinse the clothes.If your machine has a filter at the bottom clean it out .
Oct 09, 2007 | Hotpoint Aquarius WD640 Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
