Question about Kenwood KDC-MP205 CD Player
Using the auxillary setting
The only sources i can choose from are tuner cd and standby, how do i get it to auxillary to play my iPod?
  • 156 Answers
You'll need to turn the auxiliary function on in the setup menu. Press Source to put the unit in Standby, then press and hold the Menu button for at least 1 second. Press the control switch toward AM or FM until the AUX setting comes up, then press the control switch toward <<< or >>> to change the setting to ON. You can download a user's manual here: http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=69
Posted on Jun 24, 2007
SOURCE:
HOW TO USE AUX
AUX is the auxillary terminal to connect any input to the set. You must connect to the AUX input an IPOD or any device , use the conttrol panel to switch o the AUX and play the source.
Oct 28, 2010 | Sony CDX-F5510 CD Player
Can't get the Cd rb10 to play my ipod.
Most likely the radio itself has to be set to aux input. For instance my pioneer deck naturally has two source settings, cd and tuner. But in the settings I have the option to turn aux input on and then have that added to the sources. You'll probably have to look up how to turn it on from a manual.
Jun 02, 2010 | Pioneer Cd Rb10 Auxiliary Rca Input...
Idont know how to get my aux. to work on my car cd player
You have to have the Auxillary cable plugged into the radio, and have it plugged into your device (ipod, phone, mp3 player) then hit the source button until you see Aux, then you have to start the music on your ipod or whatever your using and it will play through the car speakers
Apr 07, 2010 | Kenwood KDC-MP335 CD Player
How do i get my ipod to play through the aux line in? i try changing source but only has tuner / cd / standby Thanks
hi their u might have to go into options on ur head deck try holding down a button to display options and hopefully theirs aux input!!!! and make sure ur pluggin into the ipod is in ur earfones hope that sorta helps u cheers.
May 23, 2009 | Car Audio & Video
Can't get the auxillary to play or even come up
when its on standby hold the menu button and then use the right nob to change aux on then press menu again and src untill aux shows. hope this helps
May 29, 2008 | Kenwood KDC-MP235 CD Player
Can't get into AUX source
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Sep 13, 2007 | Kenwood KDC-MP232 CD Player
Cannot select different sources
There is an easy solution for this, put a cd into the stereo and then go through your sources, it will now show standby, tuner, cd.
Aug 08, 2007 | Kenwood KDC-MP335 CD Player
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
Kenwood KDC-MP205 CD Player Logo
341 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
