Question about Morphy Richards Kitchen Appliances - Others
Breadmaker tripping RCD
I have plugged this new breadmaker into the mains but when the heating element comes on it trips the RCD's.
SOURCE: Breadmaker not kneading
A lot of breadmakers function exactly as you describe functioning normaly. The heater comes on to warm the ingredients to about 110 degrees. This heating takes place for 10, 15, or 20 minutes before kneeding starts. mhbtall@juno.com
Posted on Jul 27, 2007
  • 49 Answers
SOURCE: suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Posted on Feb 19, 2008
  • 1462 Answers
SOURCE: Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
Posted on Sep 22, 2008
  • 44 Answers
SOURCE: Washing machine tripping RCD
electrical short in m/c.could be heating element. regards
Posted on Jul 30, 2009
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Posted on Nov 02, 2009
Smeg gb-ie
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 12, 2013 | Smeg Ovens
SMEG OVEN BRAND NEW WON'T HEAT
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Sep 08, 2012 | Smeg Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
U1442 main oven not heating
If you are sure there is 220v going to unit, it most likely is element or click / control. If you have a ohms meter, you can test the element
Sep 07, 2017 | Neff U1721 Double circotherm Electric Oven
Oven will not heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
Jul 04, 2011 | Zanussi ZBF260 Electric Single Oven
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Jul 30, 2009 | Washing Machines
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
Main oven problem
Sep 22, 2008 | AEG U3100-4 Electric Double Oven
Suk92mfx5 main oven problem?
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Kitchen Appliances - Others Logo
277 people viewed this question
Top Morphy Richards Kitchen Appliances - Others Experts
Mike
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
