Question about GE WSXH208A Front Load Washer
Water does not pump out
Water outlet appears to be cloged , cant find a place to clean
  • 1,543 Answers
If you have the WSXH208A that you posted under, you will have to take the lower front panel off (one 1/4 inch hex screw on each side, right by the floor) then take the hoses off the pump and the two 5/16 hex screws that hold the pump down. Be ready to soak up the water that is still in the hoses and pump when you remove the hoses. Clean the coins and other obstructions from the pump inlet hose and make sure nothing is inside the pump. Reassemble pump and hoses and test. Should be a Fix-Ya for your machine!
Posted on Jan 18, 2009
I have a keystone springdale 311ressr. My water pump is under the carpeted step by the bedside stand. There is no access panel that I can find. How do I get to it to winterize?
Drain the supply tank (or run the pump until it sucks air) then pour a little RV potable antifreeze into the supply tank, open each faucet/outlet -- one at a time -- and run the pump until antifreeze appears at that faucet, close it and go to another one until all are running antifreeze - they color it to make this easy. All piping and pump and tank is now full of antifreeze and protected. In the spring put a little fresh water with a dose of chlorine bleach in the tank, run that through all outlets, fill tank with clean water and run that until you can't smell chlorine. System is clean and ready for use.
Oct 19, 2016 | RVs
I have audi tt coupe 2009.water is going in through the fuel cover.
THE WATER IS NOT COMING THROUGH THE FUEL TANK COVER TRUST ME!!!!!!! WHERE DO U FIND WATER?BEHIND THE SEAT OR SEATS?IF SO THE DRAIN HOSES ARE EITHER CLOGED OR SHREDED... IF U NEED MORE HELP LET ME KNOW....
Feb 26, 2015 | 2009 Audi TT Coupe
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Ec702 delongi is not pumping for espressor but steamer works
first perform a chemical cleaning, place the chemical in the water tank and then this hot place to make coffee, so that the chemical clean pump and piping hot water, repeat this until you spend all the water,
if not repaired you may have problem with the water pump, solenoid or inlay is great need to remove the tubes and clean them out
ramon
nomarpartsupply.com
Sep 01, 2014 | DeLonghi EC701 Espresso Machine
I have a 90 Chevy Camaro that will stop running while driving , and after several tries it will start but sometimes it runs like its running out of gas , other times it will idle ( rough ) but won't take...
Fuel filter cloged,fuel pump (ceck voltage,pressure),fuel line cloged (air pressure cleaning),Rare:blocked breather,tank cap(make vacuum,the fuel cant get pumped to engine)
Oct 26, 2013 | 1999 Chevrolet Malibu
Error code E2 on Washer machine Frigidaire FWLI1162DEWM
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jan 19, 2013 | Washing Machines
Gaggia titanium - between cups of coffee, we leave the machine on. After only a few minutes, the machine makes a loud clicking noise, and then the noise speeds up. A very loud, clicking noise, very...
Hi, That loud noise is the pump, pumping without water running through it. Thats not good. Will do expensive damage to whole machine if let go. It needs flowing water to stay operating for a good life. Already sounds like an ECU board. It may only be trying to rinse itself, but is cloged, and cant get enough water into it. It needs to be looked at by a repairer. I can helpyou there if you live on the sunshine coast. Dazza
Aug 21, 2011 | Gaggia Titanium Espresso Machine
The water will not drain and the spin cycle will not work.
Open bottom of machine and check the drain pump to make sure it's not clogged.
Mar 12, 2010 | Washing Machines
I have a 1999 Ford SHO that needs a new waterpump. I need to know how to replace it and where I can get a schematic of it. Do I need a special tool kit to do it? I'd also like to know where I can get the...
www.autozone.com
They can get all the parts. They also provide haynes repair manuals, any special tools (probably not required for this vehicle) and any special disassembly instructions.
I hope this helps.
Mar 11, 2010 | 2001 Ford Taurus
SANYO MODEL STWO923H1 CANT FIND THE PAN DRAIN
find the drain outlet and use a wet vac to extracate the water from the pan Slime has appearently clogged the drainage tube Good Luck
Dave
Oct 02, 2009 | Heating & Cooling
GE WSXH208A Front Load Washer Logo
66 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
