Question about Bernina Sewing Machines
Broken take up lever on bernina 730
Can i repair my own 730 record bernina,replacing the broken take up lever?
RickE1
  • 202 Answers
SOURCE: Replace Gear Stack Cam on Bernina 730
This is a very common problem with these machines. First of all you have to have a new camstack gear. Then you may need a tech to do it. The gears can be found for purchase on the internet with a search. If you feel you want to do it yourself contact me and I'll tell you how but its very involved and many things have to be done just right for it to work.
Rick
Posted on Apr 21, 2009
  • 8 Answers
SOURCE: Bernina 730 Can't open top cover !
The problem is that of a stuck piston detent on the pattern selector support that snaps the top cover closed.
  1. Open the light cover
  2. Apply pressure with thumbs on the bottom edge of the top cover on both the right and left sides of the cover. The cover should pop up...Too much pressure on the left side, (if this thing is really stuck) and you might break the top cover at the thread tension slot. Be careful here....
  3. Add a drop of acetone (fingernail polish remover) to the piston detent and work it free by pushing it back and forth. Avoid getting any acetone on the painted surfaces of the machine.
  4. Continue to work free, repeating with a few drops of acetone, and wipe clean. Don't oil this part. It was a petroleum product combined with a galvanic process (aluminum and steel) that caused the problem in the first place, not to mention age.
  5. Use DTE Heavy Medium oil rather than a white or clear oil when you lubricate your machine. White oils are unstable and will oxidize (decay) much more quickly. Also avoid 3 in 1 oil and stuff like WD40....very bad....
  6. Oil 1/2 a drop on those prescribed areas. Too much oil is more harmful than not enough....
  7. Contact your Bernina dealer for this oil.
Posted on Sep 06, 2009
Testimonial: "To swiss_tech Great help. Very much appreciated. Thank You"
SOURCE: My Bernina 730 record can only run the zig-zag
Sewing machines needs full service now and then (every 10 years will often do). The motor on the 730 series is actually as powerful as they get on domestic machines, and handles just about everything that fits under the pressure foot. Only if the machine has been used a lot over the years are the brushes worn down, but it might need new grease not matter how little it has been used.
However, the stitch applications can sort of gum or clog up if the machine has not been used for ages. Take a look in the manual and oil ever point suggested every time you take out the machine. Try them now and then on slow speed, that might get every function to run smoothly again.
This is as good a machine as any out there, favorably compared to any new machine under 500£. It sews perfect stitches on just about any material, and is well worth a full professional service (At a shop they will always recommend a new machine they want to sell you). All kinds of pressure feet and accessories are available in regular sewing shops and online.
Check with different shops for price on full service. This is a great machine what ever they tell you.
Posted on Jan 09, 2010
SOURCE: Bernina 730
I have lost the cord lead to my Bernina 730 sewing machine and cannot get any spares locally. Can anyone out there help find a replacement.
Posted on Feb 04, 2010
  • 1116 Answers
SOURCE: need bernina sewing machine model 730 manual
Here is a download - http://www.berninausa.com/webautor-data/486/BERNINA_730_731_732_manual.pdf
Posted on Mar 14, 2010
Is it possible to replace the stitch length lever (22 in manual) on a bernina record 730?
Most likely. If the lever has been damaged, it may be found by picking up a machine (for parts or repair)--check eBay. Check with your Bernina dealer. Frequently, they will have parts from used machines.
Aug 24, 2016 | Bernina Sewing Machines
Bernina 730 how do I change feed dog pressure it is way to high not touching fabric when down??? Help please
There are actually two Bernina 730 machines (confusing, huh?). One is the 730 Record from around 1960. The other is the more modern 730 computerized model made in the 21st century.
The 730 Record has a hidden pressure adjustment. Lift the top cover and locate the screwhead on the very left side (left of the takeup lever knuckles). This screw loosens or tightens the spring that applies pressure on the presser foot.
The manual can be downloaded here, although it does not show the pressure adjustment:
BERNINA Sewing Systems
On the computerized 730, the pressure adjustment is on the screen (pg 37 of the manual):
Jun 25, 2016 | Bernina Sewing Machines
Bernina 730 Record Service manual
Service manuals are difficult to find for most sewing machines, which Bernina is not an exception. However, there is a Yahoo Group called "BerninaThirtySomethings" that has conversations, documents, photos, etc. for the vintage Berninas including the 730 Record. You can join the group (must have a Yahoo email account) and download a variety of documents including a "Setting Manual" for the 730.
Yahoo Groups
http://www.thesewingforum.co.uk/showthread.php?t=28999
Apr 15, 2016 | Bernina Sewing Machines
Where are the carbon brushes located on a Bernina sewing machine located? It is a Bernina Record 730, B2-730, EPI 2 - 40 -0803, 85/37 W 7250/min. Thank you.
THE MOTOR USUALLY HAS A LARGE SCREW. WHEN YOU REMOVE THE SCREW THE CARBON BRUSHES WILL SHOW. THERE IS USUALLY TWO. YOU CAN TAKE THEM TO A LOCAL MOTOR SHOP TO GET NEW ONES.
Dec 26, 2014 | Bernina Sewing Machines
Bernina 730
try changing the needle--one for the fabric being sewed
also the zig zag could have a worn or damaged gear or cam
or there could be a timing problem.
Apr 11, 2014 | Sewing Machines
Broken take up lever bernina 830
contact a sewing machine repairer(Bernina authorised )for the part number and part availability and possible cost for repair.
Jun 20, 2013 | Sewing Machines
Frozen button hole lever Bernina Record 730
Most likely needs a good cleaning and oiling. The old oil has turned gummy and has frozen the selector knob mechanism. Might try directing hot air from a handheld hair dryer into the interior mechanism toward the buttonhole mechanism to help get the old oil loosened. (Even if it comes loose with hair dryer, it still needs a good clean/oil to keep it all working.)
Apr 29, 2012 | Sewing Machines
Sewing Machines Logo
74 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
