Question about Microsoft Windows Vista Ultimate Edition
Drivers for PI845gl+vista
I have a PI845GL board with 512 Ram. I had installed a vista on it. but there is only 8 bit screen resolution. i want to download its graphics drivers. can you help me?
    Scholar:
  • 77 Answers
First, go and signup for a free account at http://www.driverguide.com :
http://members.driverguide.com/ums/index.php
This is the file you need to download:
http://members.driverguide.com/driver/detail.php?driverid=360605
I could only find this one driver at driverguide for your board, strange tho.
HTH,
Deboo
Posted on Jan 18, 2009
Needed Drivers For Aspire ES1-512 Laptop FOR WINDOWS 7 32 BIT
If Acer never made it compatible with windows 7 in the first place you are out of luck. They made it to work with 8, so they had no reason to support win7, therefore it doesnt and you should.... install 10! or 8.1
Jul 24, 2015 | Acer Aspire Computers & Internet
Pi845gl
Hello the driver can be downloaded here:
http://www.mercury-pc.com/downloads_list.php?productid=389
The driver maybe needs to be unziped before you install it.
If i am wrong by my selection, select the mainboard here:
http://www.mercury-pc.com/downloads.php
Good luck
May 05, 2013 | Computers & Internet
PI845GL M-L Sound Driver
101 % Working first you have to download
1. Universal audio architecture which will enable your motherboard to detect audio driver it
can be downloaded from here.
2. Then download its driver from Link 1 vga
Link 2 audio
Jan 10, 2011 | Mercury P4VM800M7 Motherboard
VGA DRIVER FOR MERCURY PI845GL-L COULD NOT FIND IN MERCURY WEBSITE. PLEASE PROVIDE THE LINK
2. Then download its driver from Link 1 vga or agp
Link 2 audio
Enjoy works 100 percent..............
Oct 05, 2010 | Mercury P4VM800M7 Motherboard
Drivers for Intel D845 GVSR mother board
The best place to download drivers is always the manufacturer's website. The Intel drivers for this motherboard are found here :)
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1065
Since the 845 graphics chip does not have internal DX9 support there are no Vista drivers for it The 945 graphics is the first Intel chip for which there are Vista drivers available from Intel.
You can try the XP drivers. All depends on how different the chips are. Be sure to set the Install.exe program to XP compatibility (Properties dialog) and then run as administrator. Be sure to create a restore point first!
Dec 30, 2008 | Intel D845GVSR Motherboard
Intel 845 GVSR drivers for windows vista
change to Windows XP,
windows vista will not support with *********** board
it will support more then 865 chipset
May 17, 2008 | Intel 845GE Motherboard
Ram problem
IT IS A SHARED MEMORY
You won't like the resolution if you remove the 8mb buffer in bios set-up, trust me.(it will make your display look like 16color windows 3.1 or worse) You could try it and it will get you back that 8 meg the other is shadow ram, don't mess with that either.
Your options in advanced video are 8mb and 1mb. My advice, leave it.
Apr 19, 2008 | E-Machines eMachines Desktop PC
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS....
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key
and
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
Apr 09, 2008 | Intel D845GVSR Motherboard
i don't know weathere you are awared of this or not...
to get the 32 bit graphic on 82845gv motherboard go to BIOS setting and change your video frame buffer size to 8 mb and agp aeperture to 256 mb and let the system boot... you will get 32 bit graphic with 1024 x 748 screen resolution... i have changed and believe me it is working
but only problem is that you will hardly play any game or use bubble screen saver..
Feb 24, 2008 | Intel D845GVSR Motherboard
Needed a video driver
as i think you will be knowing the minimum system requirement 4 windows vista it s 512 mb ram ..as i think ur s is less than that so you may be facing the hanging problem .. if so i suggest u 2 upgrade ur ram to minimum 512 .... r u install windows xp SP2....
if u have 512 mb ram then there may problem with operating system this may be due 2 d virus attack some files have became unstable ... so reinstall ur vista ....
your problem will be solved...
Feb 10, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
