Question about Holmes Products Dryers
Manual for holmes fan HTF3210a fan does not work
Blades will not work
2 Suggested Answers
SOURCE: i have a holmes blizzard fan and need to clean the
Turn the fan around there are four screws on the backside of the grille. You will need a long philips head screwddriver.
Posted on Jul 13, 2009
How do I get the front cover off the Holmes table fan HAOF90?
Should be three clips that fold over the outer cover pry up clips with a screw driver.
Jul 21, 2014 | Holmes Products Dryers
I have a Holmes HAS1650 stand up fan and I need to know how to get it to quit rotating.
Not sure what you mean by "stop rotating"
I assume you mean to stop oscillating. There should be a knob on top of the motor housing that you push down to oscillate and pull up to stop oscillating.
If you mean to stop the blades from spinning there should be a fan speed control knob on the top of the motor housing that you turn to "O" to stop the fan.
Here is an instruction manual for a similar fan...
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-holmes-products-Site/Sites-holmes-products-Library/default/v1405596036669/documents/instruction-manuals/HASF1515R_HASF1516R-UC_11EM1.pdf
Jul 18, 2014 | Dryers
My fan is not rotating when I connected to plug. There is no burning smell or anything. How can I fix the problem? Thanks in advance
Hello.
I have a Holmes pedestal fan that does this every few years. I have had this fan for about 10 years.
Unplug the fan and remove the fan blade guard. The fan blade should spin easily when you tap the edge of the fan blades with your finger. If the blade barely moves and abruptly stops, the bearings are dirty and need to be cleaned and oiled with 10W non-detergent motor oil. A quick-fix is a tiny bit of WD-40 where the motor shaft (the rod that the fan blade is mounted on) meets the bearing (the part of the motor that the shaft spins on). To properly fix this, you must oil both the front and back motor bearings which requires removal of the motor housing.
If the fan blade spins easily and you are certain that the fan is getting power (try a different outlet) the motor may be bad. Likewise, if the fan blade will not move at all. I do not know if Holmes sells motors for these fans. Here is their online support website:
www.holmesproducts.com/Support.aspx
Good luck from Detroit, MI.
P.S.: Never turn a motor-operated appliance on for more than a second if you know it's not working. That will cook the motor windings.
Jun 12, 2011 | Holmes Products HASF1710-UC Stand...
One of the blades fell off and I didn't know if we could just get that 1 blade or not.
No,sorry.You may find a replacement or a used one for parts here,http://www.buycheapr.com/us/holmes+twin+window+fan
May 12, 2011 | Holmes Products HAWF2041 Twin Window Mount...
Hi, I have a pedestal fan (16") for which am looking for spare parts. I need - fan blade (5 blades) - the clips that hold the base grill and the front grill Make: Holmes Model:...
Seriously?? It's a $30.00 fan. IF you could get parts for it, they'll cost you more that the original price of the fan, but I guess if you insist. Go here and call them or chat online, they'll tell you if parts can be had.
https://www.holmesproducts.com/fans/
Jun 09, 2017 | Holmes Products Dryers
We have two holmes fans and they both stopped working within the same week, we replaced the batteries and nothing and we tried to manually start them and nothing; any ideas>
mcdevito75 here, You say you changed the batteries in both fans, tried to spin the blades and no start., Double check battery install, try another set of batteries even new batteries from the store can be weak or even dead as batteries have shelf life of, not too long. Spin the fan blades as fast but as safe as possible by hand with the on /off switch off, and listen for any noise from the fan motor, a sraping sound, or whistle could mean a bad motor. Lastly, bring the fans to a Staples, they will be glad to test them, a Radio Shack also can test the fan motors.
Jul 28, 2010 | Holmes Products HAPF622R Floor / Box Fan
I have a holmes blizzard fan and need to clean the blade. how do i take the front cover off
Jun 30, 2009 | Holmes Products Holmes HAOF951T-U Blizzard...
Cannot remove blades
hi! there,
there are two type of removing the blade of electric fan,one is there is a center knob with mark arrow loosen and tight direction at the center holding fan blade, this to lock fan blade on its shafting. to remove fan blade.loosen holder knob on clockwise direction while holding the fan blade,to release the knob check the arrow on the knob. after loosening knob pull out blade from the shafting.
the other type the fan blade has lock in bolt at the back side of the fan blade bolt in on the shafting of the fan, you need here a tools such as set of socket wrench small one to loosen the bolt
after loosening lock in bolt, pull out fan blade.
besure doing this tha electic fan was unplug to elecrtic source. have a nice day.just rate me,thank's
Apr 18, 2009 | Heating & Cooling
Grinding of fan
There should be a black round nut in front of the blades in the very center. It will have ribs on it so you can grab it. Turn it Counter clockwise, and it should unscrew.
Then you can remove the blade assembly and get to the back cage to tighen the screws.
This should take care of the problem.
Re assemble in reverse order.
Let me know if you have any more questions or if this doesnt work.
Good luck.
Mac
Aug 19, 2008 | Holmes Products HASF1516 Stand (Pedestal)...
Dryers Logo
109 people viewed this question
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
James Coghill
ray gallant
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
