Question about Panasonic PV-V4020 VHS VCR
Tv monitor turns blue during forward or reverse vcr search
Just switched my panasonic vcr to a newly acquired used tv (maganavox 20ms2335). the tv screen turns blue after a few seconds of normal functioning when i try to forward or reverse search a videotape recording.
  • 398 Answers
On some TV's the screen will go blue if there is not a strong, solid video signal present. This is to prevent the showing of very snowy or all snow channels, or garbled, mixed-up external video signals. This is normal. On some VCR's the video signal changes when the FF or REW search feature is used, and this could trigger the TV to go to blue screen. The only way around this if you can enter the TV's menu and turn off the blue screen feature.
Posted on Jun 28, 2007
SOURCE:
My Steelmaker SW A 2000, recently acquired, sewed fine when I got it home, now it won't feed the material through so it can sew properly.
That sounds like a problem with the height of the feed dogs. Can you see them raise and lower? My advice with any newly acquired sewing machine is to have it cleaned, lubricated, serviced and the timing checked.
click on the link
sewing machine servicing near me Google Search
Jun 09, 2018 | Sewing Machines
Big Button Remote Control
This is because you did not use the right remote code. Try trying different codes and test different functions with your recorder. Try searching on the Pioneer wesbite for remote codes. I would get the codes for you, but I don't have your model number so I can't. You can search for them yourself or comment back informing me of the model.
Hope this helps :)
Jan 25, 2008 | Televison & Video
My VCR won't interface properly with my TV. Any time I try to play a tape, all I get is a blue screen. I've tried using it with an older TV, and the tapes play fine. Any help is appreciated.
Make sure that the tv set's rf frequency is set to the same rf as the vcr. If both are identical then something is definitely wrong with the tv set since the vcr works fine with another set.
Jun 13, 2016 | Viore 32" LED LCD HDTV
I HAVE A Panasonic universal remote,I can not find the code for my Magnavox TV
Check these codes. These are the four digit codes for Maganavox TV.
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
Jun 25, 2012 | Panasonic TBC Remote For S-VHS Deck Remote...
How do you program into the dvd that you want it to fast forward quickly? There is a way but am not sure how it is done.
You don't, you just press the FORWARD button on remote during DVD playback to 'fast forward' (pressing this button a second time during playback increases forward scan speed). The forward and reverse buttons have 'SLOW/SEARCH' printed above them on the remote. The other buttons next to them are the PREV/NEXT buttons (SKIP/INDEX).
DVD playback speed/skip/search is mostly a manual user function; it cannot be auto set.
May 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic TV Model PV-C 1320
There should be a TV/AV button located with the front control buttons, press this & it should switch over to the AV source ie. your camera input.
Sep 02, 2009 | Panasonic PV-C1320 13 in. TV/VCR Combo
How Do I Tune VCR to the TV
I have a panasonic analogue television, and I cannot tune in a Goodman VHS VCR to the television. I have no remote controller for the television, and use the buttons on the front of the set to change stations 1-5. I have however found AV on the television screen and the indication is that the VCR is trying to come through when switched on. I have got a remote controller with the VCR. Can you help me please ??
Mar 14, 2008 | Televison & Video
Recording on a Panasonic VCR
This problem is undoubtably dirty or worn video heads. Try using a good quality head cleaning tape. If this fails, re-post, and I will explain how to clean heads by hand.
Dave Duff
Mar 01, 2008 | Panasonic PV-V4022 VHS VCR
Tapes wont play in palmcorder vcr mode
just clean the video head and you will get the image.
Oct 31, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic PV-V4020 VHS VCR Logo
468 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
