Question about Husqvarna Chain Saw 20" Bar
Pressure clutch on Husqvarna snow blower wore out in 8 hrs use.
The hard rubber pressure disk that drives the wheels on a brand new husquavarna 30 inch cut snowblower wore down almost all the way through ity in 8 hrs use. There was no visable sharp edges to ware thru. I never drove it into a snow bank and let the wheels continue to turn. I would feather the drive handle making it go slowly. They was using it incorrectly but didn't tell me how to drive into a snow bank to blow it. What could I have been doing wrong?
5 Suggested Answers
  • 16 Answers
SOURCE: husquavarna 350 chainsaws
there is a spdecial tool but you dont need it. i use small flat screw drivers between drum and shoes and fit new springs with a circlip pliers
Posted on Nov 11, 2008
  • 132 Answers
SOURCE: while cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
Posted on Jan 02, 2010
nedkelly900
  • 345 Answers
SOURCE: Reference the Husqvarna 350 chainsaw. Why does
Sounds like the clutch is still grabing. Easy solution is to apply the chain brake at idle to stop the chain turning. Try adjusting the L screw for a smoother idle.
Posted on Aug 05, 2010
  • 2239 Answers
SOURCE: I used my brand new Husqvarna chain saw for about
The chainbrake has actuated, you need to pull the hand gurd fully toward the rear of the machine until you hear the click of the brake unloading.
Posted on Jan 14, 2011
  • 250 Answers
SOURCE: New Husqvarna 30 cc 2Cucle
Turn the switch to on, push the primer bolb about 8 times to get the fuel up to the carburetor, put the throttle about 1 quarter to a half way up, put the choke on closed and it sohould start. When it sputters open the choke slightly. Let it warm up and open the choke completely.
Posted on Mar 19, 2011
My simplicity model 870s snow blower jumps or I should say falls out of 4th gear.
Most snow blowers have a driven disc on the engine, and a disk with a rubber ring on the outer rim as the driven disk on an output shaft, connected to the axle of the machine. The rubber rimed tire runs on the driven disk either close to the center or further out, kind of like a record player tone arm You can adjust the drive position by adjusting the location of the driven wheel, this is usually done via the linkage which is basically threaded rod with an adjustment nut and a lock nut
Jan 13, 2017 | Cars & Trucks
Troybilt snow thrower wheels lock up cannot push or pull. Model 5524. Whats up?
Sounds like friction disk is not retracting for pressure plate. Flip snowblower up on front end and take out 4 or 6 bolt out of cover plate. wheels will be in the air so try to turn wheels and look. Your fiction disk is the rubber wheel that moves with you gear shift lever. It should not be touching round metal plate unless your handle on bars is push down to in gage drive. Most snowblowers have a spring to pull metal plate back your probably broke or rusted off.
Feb 24, 2015 | Garden
Can I get a new rubber track for an older model (not home to get exact numbers ir model) Montgomery Ward snow blower?
OUCH since monkey wards went out of business you need to see what company made it for them .it might have been mtd there were several brands with same type of drive system .
Feb 02, 2015 | Garden
How do you adjust the friction disk on a 627852X07A snow blower
Is the drive belt too loose? Mine has an adjustment that you can tighten up . Mine last winter was slipping till I tightened the adjustment.
Sep 07, 2014 | Garden
I have a 30" husqvarna snow blower. 1 year old. The auger belt is really loose and keeos slipping off the main pully and smoking like crazy. I replaced with a new belt and still had the same problem. Any...
Page 17, figure 23 of the manual shows a "Clutching Idler Arm Bracket" that should take up slack. Does it have a broken spring, or is it seized because of ice or rust? The very top of the page does mention that the belts aren't adjustable, but why else is the idler arm there if not as a tensioner?
http://www.husqvarna.com/ddoc/HUSO/HUSO2011_NAen/HUSO2011_NAen_1830EXL_532443434.pdf
Dec 14, 2013 | Husqvarna 1830EXL 30" 414cc Crown Series...
Honda hs55 when handle depressed blower fan moves at fast speedauger turns very slow.if auger makes contact with snow auger and blower fan stopsnew belt was installed no slippage of belt present
I suspect that all is needed is a little adjustment of the rod attached to the handle, which hooks on a lever at the bottom of the snow blower drive axle case. Try adjusting the nut two turns, that will pull the rod a little bit more and engage the rubber faced drive wheel, giving it a snugger connection. If this has been checked or still does not help, then I would check inside the case where the drive axle is located. There is a rubber faced drive wheel (as noted above), that runs against a smooth flat metal pulley. The rubber on the drive wheel could be worn out and not engaging properly. I would also check on the front of the case where you installed new belts to make sure that the brake shoe puck that connects to the auger pulley is not binding or perhaps has flipped out of its normal location.
Dec 05, 2013 | Honda Piston Rings Snow Blower Lawn Mower...
Husquavarna 455 chain oil problem
is the tin plate on the right way?(not blocking the hole)did you change the bar and the replacement blocking the oiling hole
Aug 19, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a MTD 5/20 snowblower that won't engage in Forward. It will transfer to neutral and reverse, but I can't any forward power. If I tilt it forward, the wheels will spin. I installed a new belt and...
ALL SNOW BLOWERS HAVE WHAT THEY CALL A FRICTION DISC DRIVE IT SOUNDS LIKE THE FORWARD SIDE OF THE DISC IS WORN OR THEDRIVE WHEEL HAS A RUBBER DRIVE RING THAT IS WORN. IF YOU REMOVE THE BOTTOM PLATE YOU WILL SEE TWO DRIVE WHEELS ONE IS JUST A METAL DISC AND THE OTHER LOOKS THE SAME BUT HAS A REBBER RING FOR GRIPPING THE DISC TO MOVE THE BLOWER FOREWARD, WE END UP REPLACING ALL THE DRIVE DISC AND DRIVE WHEELS ON OURS EVERY SPRING THE FOREWARD DRIVE TAKES THE MOST PUNISHMENTTHERE FOR WHEARS OUT THE FASTEST. MTD HAS A WEB SITE FOR ORDERING PARTS AND ARE NOT HARD TO INSTALL.GOOD LUCK LET ME KNOW HOW IT GOES
Feb 05, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
My drive does not engage I checked the clutch cable ,the drive wheel rubber is worn but still sufficient,it could be a shear pin but I dont know where it is I have an MTD/5/24 its likely at least 10 years...
There are a few things to check on this unit First is if the pins are in both tires. the quick pins are removable and allow for the machine to freewheel for easy transport.
I would check to see if the drive disk is coming to a stop when the cable is tensioned properly and engaged. If it stops then the belt needs replaced. There are a few updates on the different models for idler pulleys. I would recommend checking with a shop like www.arcolawn.com to get belts and check for updates.
If the drive disk is spinning and the pins are in then the problem is from the rubber drive disk to the axles. If there is no grinding from the transaxle then the problem is in the clearance of the drive disk.
Good luck.
Feb 04, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Husqvarna Chain Saw 20" Bar Logo
577 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
