Question about Sewing Machines
Shuttlecock is frozen in position
Wheel will not turn. took out bobbin case. shuttlecock seems to not move
SOURCE: Fabric won't advance, bobbin case not turning, feed dogs not moving properly
It's a Singer 5830C -- schooling machine. It's crappy. I'm guessing that a new machine is my best option. For the time being, I'm using my mother-in-law's old metal Nelco.
Posted on Jul 26, 2008
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Posted on Aug 07, 2008
SOURCE: while sewing the bobbin case moves, wheel locks up, needle locks
Im not sure if this will help but thought I would pass it along. My Pfaff 6122 tells me to check bobbin for thread unrolling clockwise before you place it back in the machine. I had mine turned to un roll counter clockwise, this is wrong, the bobbin will fall out when you pull on the thread while you are holding it in your hand. You may just keep putting it in backwards. Hope this works for you. J.R.
Posted on Feb 05, 2009
  • 4 Answers
SOURCE: Replaced Singer 5932 bobbin case, need help. *pics*
there may be uneeded friction occuring. are you sure you inserted it correctly? sorry. photos aren;t appearing. but it may be that it is the wrong type or in the wrong place. do some trial and error and fit it into different positions on the bobbin runner
Posted on May 11, 2009
  • 7 Answers
SOURCE: Problem with spinning bobbin case base of my Pfaff 360 sewing mac
on lockstitch machines with rotary hooks the base[the bit the spoolcase fits in]is held in place by a retaining finger,tip machine back and you will see a long finger with a right angle lug sticking out approx 4/5mm .loosen the screw holding the finger only slightly and spin the base till the top of the base is at the 12.00clock pos.[it will help if you take needle plate off]the lug fits into the cut out of the base.then tighten finger screw and try. if base is jammed you will need a mechanic to dismantle hook and repair and retime the machine.
Posted on Jun 24, 2009
Why is the hand wheel so tights
It shouldn't be too tight. Clean out and remove the bobbin/bobbin case. Now, try to turn it. Does it turn any better? If it does turn easily without the bobbin case and bobbin installed you know the bobbin case was out of adjustment.
To adjust the bobbin case reinstall the bobbin case. Slightly move the hand wheel back and forth. There should only be slight movement of the bobbin case. The bobbin case is held in place by a small piece of metal next to the bobbin case.on the lower right corner. Just make the adjustment to prevent the case from movement.
The hand wheel can also be prevented from movement due to the interior parts of the machine being filled with dried greese. If you're feel safe about this you can remove the front, back, etc and inspect for buildup. Clean it up with carburetor cleaner and a qtip. Try not to douse the plastic gears with this. Clean it thoroughtly. Put sewing machine oil on all steel against steel movement. Any plastic movement should be done with a non petrolium product like silican spray. You can move the hand wheel a great deal to observe any parts that may have movement probmems.
Jul 08, 2017 | Sewing Machines
Pfaff 2014 bobbin casing has thread - needs to be removed - how?
I had this problem with my 7570. I kept trying to wiggle the hand wheel. Took everything apart I could to get at it. Finally after many try's it moved and I was able to use a tweezers to get the tread out. A friend suggested applying a drop of oil to the bobbin case and letting it sit. She said it would desolve the thread some so you could move it.
Apr 03, 2013 | PfaFF Sewing Machines
Bottom thread from theh bobbin is in big loops.
Problem with Brother CS-8150 Computerized Sewing Machine
bottom thread from theh bobbin is in big loops.
I have a CS-8150 as well -it was fine until I decided to clean the shuttlecock and I thought I had put it back correctly. However, it was after replacing the shuttlecock in place that my bobbin thread was making big loops and no matter what tension it kept doing it. So I removed everything out of the bobbin area. Cleaned and made sure that the shuttlecock was exactly in place as per the manual. Guess what it does not make big loops any more.
Just a suggestion.
Sep 09, 2011 | Brother CS-8150 Computerized Sewing...
I have a singer cxl electronic sewing machine and i have a problem with the needle either not moving or stopping when stitching the larger motifs or the zigzag stitch, somtimes the needle jut moves too...
The needle either not moving or stopping is a sign that the machine is jamming. Here's the answer for the question "My machine is jammed" from the FAQs on Singer's web site at http://www.singerco.com/support/faqs.html
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Your description of the needle hitting the plate or foot is an indication that the machine's timing has become unaligned which can be caused as indicated above by turning the hand wheel away from you - the correct way is to *Always turn the hand wheel towards you.
Mar 03, 2011 | Singer Sewing Machines
While sewing the bobbin case moves, wheel locks up, needle locks
Feb 05, 2009 | Brother CS-6000
Can't get the bobbing holder back in place
lambchopp22 the bobbin case "the black thing" can be tricky to get back in but first you may need to get a new bobbin case because that is what can cause the whole bridnesting thing check to see if you have a nick or a hole in the bobbin case. then be sure you have the bobbin in correctly this also can cause the bridnesting thing to happien. after you make sure that the case is ok or get a new one turn the hand wheel toward you until the metal hook is at the one o'clock postion you might have to move the hand wheel back and forth to get it to slide in correctly. hope this helps you out
Jan 28, 2009 | Singer Inspiration 4210 Mechanical Sewing...
Hand wheel won't turn
I continued to try to get the bobbin out. I finally decided to break it out. Once it was out I tried pulling the case out so I could see if anything was jammed underneath. It took a lot of work but it finally popped out like the manual said it should. I cleaned it out, nothing really dirty, no thread jams. When I went to put it back together I noticed that the way to put it back was not the way the case was sitting when I took it out. So I figure that my son must have jammed it and somehow knocked the bobbin case out of alignment. I put it back in correctly and it works just fine now!
Jul 06, 2008 | Brother CS-6000
Wrong type of stitch/tension not working
Found a solution to my own problem.... hope this helps someone else. Make SURE the bobbin case is seated correctly! (follow the instructions carefully). Don't put the cover back on right away after you put the bobbin case in. First check and make sure it doesn't move when you turn the hand wheel.
Also, when threading the bobbin make sure the thread passes down through the tension adjusting spring of the bobbin case.
May 14, 2008 | Brother CS-6000
Kenmore 385 series
The bobbin case is most likely not adjusted properly. The bobbin case has a small piece of metal that can be loosened with a screwdriver. Once it is loose you need to move it to a point that won't allow the case to move. The bobbin case must only be moved to a point to stop the bobbin case from movement. If it is too tight it will cause the machine from sewing.
Jul 05, 2017 | Kenmore 16622 Mechanical Sewing Machine
Sewing Machines Logo
61 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
