Hi does somebody have the specs for a cerwin vega v33?
2 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: Cerwin Vega V-35 Horns Drivers Model TMH-1
first you need a multimeter set to OHM , check on the back of the horn , remove the leads and do some reading , it should read 4 , 8 , 16 ohms depending of the brand , if you get no reading its means that need to be replaced , some horns you can detach the back (magnet w/the coil ) so you can replace it without buying the whole unit . good luck
Posted on Apr 19, 2008
What is the voltage and wattage of the Cerwin Vega E-715 speaker fuse?
Speaker fuses are rated in Amps. If you cant find the specs on your speaker via google, (I couldn't find anything on the fuse.) start with a 2 Amp 'slow-blow' fuse. That should work at low to medium volumes. If you find it blows at low volumes, move up to a 4 or 5 Amp fuse. E-715 is a big speaker, (handles 400W!) so starting at 2 amps should be pretty safe.
Feb 11, 2016 | Cerwin Vega Audio Players & Recorders
My Cerwin vega xls 15s doesn`t work!
Blown circuit. The question is; was it the power supply that blew out or was it the amp? check for fuses and see if they are ok. If they are not, replace them. IF they are then you are going to have to get new amp and or power supply.
Apr 26, 2013 | Cerwin Vega Audio Players & Recorders
What is the omhs of a cerwin vega avs sat4 surround speaker
According the the Cerwin Vega manual for this model and others, all speakers in the system are rated at 8ohms. This includes the Sat4 Surround Speaker and all other channels.
More information can be found at Cerwin-Vega's service and support page at: http://www.cerwinvega.com/product-manuals.html
You can also call them for information as well.
Mar 19, 2011 | Cerwin Vega AVS-5.1 System
I wanna know what the specs on this amp i just bought one recently
Cerwin Vega Vega-7000
2 x 175W @ 4 ohms (12V - 0.05% THD)
2 x 350W @ 2 ohms (12V - 0.10% THD)
1 x 700W @ 4 ohms bridged (12V - 0.10% THD)
http://ampguts.com/gallery/showgallery.php?cat=506
details and pics of cerwin amps on this site above.
Jun 22, 2010 | Cerwin Vega 2 Channel Amplifier - Vega...
Goodday im looking to get the box specs for the
It should tell you in the spec sheet. Go to Vega's web site for support on their product.
May 16, 2010 | Cerwin Vega Stroker 12 Car Subwoofer
I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
Box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Feb 14, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Speaker Box Specs??
i need to know what the box dementions are for a 15 inch cerwin-vega subwoofer v max 1000 w peak power?
Mar 24, 2008 | Audio Players & Recorders
81 people viewed this question
 Grubhead
Grubhead
