Question about Microwave Ovens
We recently bought a Panasonic "the Genius Sensor 1200W" and God are we on our last straw. It won't start on the first try... We have to press the same thing 3 or 4 times while holding the door at different places. At one point we thought it was locked - child but I just unlocked it with no luck. I want to throw it out the window but it was pricy and that would be stupid. Help!!!
During cooking,microwave stopped,no power.
Not good news; Panasonic uses a technologically superior power supply with higher efficiency but an overall worse record than those using a 'linear' supply with far fewer parts and a good track record of reliability.
The modern (switched mode) power supply places a lot more stress on components and requires more and higher quality parts than the old-style circuit.
Feb 21, 2015 | Panasonic NN-SD681S - Genius Prestige...
Panasonic genius 1200w
You may have a failed keypad or moisture or grease on the keypad innards or on the control circuit board itself.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes if it's an over the range model.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
May 02, 2013 | Panasonic NN-H764 Microwave Oven
Panasonic inverter 900w microwave fault code h97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Sep 14, 2012 | Panasonic Genius Prestige Nnsd997s...
On our Panasonic the genius sensor 1200w microwave the bulb burned out so replaced. After replaced turned light switch on both bulbs turned on and right away one bulb burned out and now the switch will not...
Mine burned out within a month. Probably due to the poor design of the machine which forces you to slam the door to get it to shut.
My biggest concern is the under counter lightbulbs it has burned out in my kitchen over the last year. I wonder how much leaking this thing really gives off. Moving in a few weeks and will be throwing this cancer machine out.
Sep 09, 2011 | Panasonic NN-H764 Microwave Oven
What size watt amp is needed for my panasonic the genius 1200w microwave
I am not sure what you mean. If you are asking how much power it draws in Amps, that is printed on the rear panel as Watts. It depends on your mains voltage.
Feb 22, 2011 | Microwave Ovens
Our Panasonic "the Genius" Model No. NN-S562WF 1200W Microwave has the following problem: We set it for the required minutes, it goes for about 40 seconds then stops - there is no heat happening at all.
hi that is one of 2 possible faults it is either the magnetron or the invertor board (panasonics "great idea" of replacing 3 simple more reliable components (transformer capacitor
Aug 30, 2010 | Panasonic Microwave Ovens
Panasonic Microwave Genius 1200W stop working. I move a little bit electric cord and it went on again. Then I pressed one min quick reheating. It blinks and stop working. Any solution ?
Assuming that you mean the whole unit goes off as if you unplugged it then the problem sound like the incoming power//you say that if you moce the cable then it comes on untill you try to use it //replace the whole cable from plug into the machine
Dec 29, 2009 | Microwave Ovens
Our Panasonic Genius 1200w microwave stopped working all of a sudden. It's completely dead - even the front panel. Is it worth fixing?
It could be just the fuse and fixed for a couple bucks. Only way to know is open it up and check it. Eric
Sep 03, 2009 | Panasonic NN-H504WF Microwave Oven
1200w Genius microwave, about 4 years old. Has been working no problem until today. When I press start, its starts ok but cuts out after 23 seconds. It does this on every setting.
The 22 seconds is the giveaway. In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 20, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
