Question about Refrigerators
Norfrost freezer manual max min setting
Which is coldest min or max
  • 250 Answers
SOURCE: re maytag fridge with mim max dial
max
Posted on May 18, 2010
heatman101
  • 43501 Answers
SOURCE: Freezer is not freezing food
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 27, 2010
bobicehouse
  • 1524 Answers
SOURCE: having an issue with freezer settings, what is the
7 Is the coldest whereas 1 is the warmest
Posted on Nov 29, 2010
  • 196 Answers
SOURCE: Is the Min button on
No max is the coldest. Good guide is to set the dial in the middle.
Posted on Mar 15, 2011
rohntech
  • 422 Answers
SOURCE: My freezer isn't reachintg the
Have these temp control dial be check.
If it is defective it's either defrosting- no ice or freezer is full of ice.
Check if you can or call a service technician to do that.
I hope I help you to your fridge problem.
Posted on Jun 28, 2011
My norfrost chest freezer hardly opens.until a couple of hours?is there any timing for norfrost chest freezers?
switch of your freezer. and turn it on after half an hour. may be it works.
Dec 13, 2011 | Freezers
I have a kenmore upright freezer and can't remember which setting it should be on. It has coldest 1 2 3 etc.
I keep min two notches from the coldest setting.A great way to check where you should set yous,is ice cream.Put an open container of ice cream in the freezer,and turn the freezer to coldest.The next day try to scoop the ice cream.If the ice cream is hard the freezer is too cold.Adjust the freezer two notches ,and try the ice cream the next day.Repeat till you are happy with the hardness of the ice cream.It should be easy to scoop but not too soft.
May 17, 2011 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Is the Min button on a servis fridge freezer the coldest setting?
Mar 15, 2011 | Refrigerators
The refrigerator is not getting cool. The freezer side is working properly.
If youre freezers making ice, and the ice remains dry, there is nothing wrong with the refrigeration cycle or components, the issue is merely insufficient airflow from the freezer into the refrigerators box.
The reefer box is 100% reliant upon the freezer for all of its cooling capacity the reefer section is a byproduct of the freezer, only the freezer has an evaporator coil, there is a small duct between the two sides, the freezer box and reefer box and a movable flapper door/damper that allows or disallows the freezers cold air to migrate into the refrigerators section.
This is a huge and common issue as evidenced by the numerous examples posted here saying, My freezers fine, but reefers warm!!! Impossible actually, unless the damper door that modulates the freezers airflow into the reefers box is closed down, not allowing enough freezer air into the reefers box.
Now when one sets a temp on a reefer the thermostat with the 1=10 and off setting that will cyle the unit off is the 1st place we go, and we raise the setting to cooler temp desired, or max it out most commonly as more is better?? NOT! Sure its fine to peg, max or increase the thermostats setting to the coldest seting, if you want a colder reefer box.
However where the counter intuitive labeling of the remaining dial or setting is where everyone messes up and actually exascerbates the warm reefer box isssue they discovered and attemptef to rectify by peggimg, maxing or at least raising the coldness desired .
The remaining setting has no electrical circuits and cycles no compressor or fan or anything except closing or opening the door that seperates the freezer box and reefers box
If you will notice the writing carefully it says cooler and warmer, or colder warmer etc.
The logical thing to do and waht 99% do when they suspect the reefers warm is raise both, or max both, which males for a colder freezer temp not the reefer! if the dampers ets at max or coldest is shut odff to the reefers box, allowing for a colder freezer as was stsated on the dial only thing is its for the wrong box!! If the freeezers ok and making ice that is dry the setting for airflows off or broken or damper doors stuck obstructed, I cant telll you how many times i billed $85 bucks to set the damper in the middle setting whrre all the dials should be anyways!!!
Dec 27, 2010 | Samsung RS2630SH Side by Side Refrigerator
I recently bought a norfrost chest freezer model c6aew,the freezer did not come with a manual or guide.i switched on the freezer set the dial to seven waited 24hrs and put some food into the freezer to...
Can't help I'm afraid, but we have exactly the same problem with exactly the same model. Ours did work for nearly 2 years, but recently only works with the boost button pressed in. I suspect the thermostat is not working as the boost button over-rides the thermostat to give max cooling. Your freezer is new so get it exchanged; it certainly doesn't need to be full to work!
May 29, 2010 | Freezers
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Deciding which way to turn the dial to get the minimum temperature
Coldest when you are on the higher number or higher letter. Ave setting should be around 3 on a scale of 1 to 5.
Apr 12, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
