Question about Compaq Presario Notebook
No display on expantion vga port for projector
HI,
I m using presario c702 tu notebook.
i want to connect lcd projector. as normal course i have connected it then ennabled clone display option in intel graphics properties. but didnt getting display on the projector.
another way i have tried with function key with F4 still didnt getting display.
please help
manoj.
The problem might be related to your native screen resolution. The C702TU laptop has a resolution of 1280 x 800. Most projectors do not support this resolution and if you cloned the main display, your projector cannot sync at this resolution. Look for an option to output a second display )instead of cloning) within your display settings. If your projector is plugged into your VGA port and turned on, Windows usually detects the second display automatically. Change the resolution on the second screen to something like 1024x768 or 800x600. These resolutions are supported almost universally across projectors.
Posted on Jan 18, 2009
How do i connect compaq presario x1000 to external monitor
Hi Judy,
The Compaq Presario x1000 notebook offers connections for external displays at the rear below the screen hinge as show in the picture below:
Identifying the back from left to right: Ventilation slots, External VGA Port, S-Video Port, USB Port, USB Port, RJ-45 Network Jack, RJ-11 Telephone Jack, Parallel Printer Port, USB Port and 1394 (a.k.a. "Firewire") Port.
You can connect a VGA monitor to the VGA port (blue colored jack) very easily. Any analog VGA monitor should readily connect to it. Additionally, the x1000 can output its display to TV or other monitor that accepts "S-Video" signals. An "S-Video" cable will be needed to connect between the "S-Video" jacks on the notebook (next to the VGA Port) and one on the TV. It is important to note that not all TVs support both or either "S-Video" or VGA inputs. When ever the there is a choice of using S-Video or VGA on a TV or monitor, the VGA will provide the best looking picture, and should be used.
I hope this helps and good luck! Please rate my reply - thanks.
Oct 03, 2011 | Compaq Presario X1000 Notebook
I have an Acer One netbook and tried to connect it to a projector but the normal looking lead from the projector did not seem to fit. The lead has those two wee screws at the side, and no place for them...
The Acer One netbook has a mini-VGA port on its left side. Page 10 of Acer's QuickGuide shows the port as item 3 External display (VGA) port. But unfortunately, the description shown for it is incorrect.
From your description, your projector's lead likely has a mini-VGA connector on the end as pictured. The connector can simply be plugged into the mini-VGA port but there are no holes beside the port for screws so it would just be a friction fit which should be sufficiently secure for most puposes. The connector and port are mini-DB 15 male and female respectively and can only fit one-way. The port has the wide side of the D on top so you would have to turn the pictured connector over to be able to plug it into the port. Windows XP should be able to detect the projector via plug-and-play installing any display drivers if required. Page 8 of Acer's UserGuide describes Hotkey + Display toggle which switches display output between the display screen, external monitor (if connected) and both. Pressing + with the projector plugged in will bring up a window in the middle of the screen allowing the selection of internal display, external display, both, or a 800x600 VGA projector. If the display is on the projector, unplugging the cable should automatically revert display back to the internal screen. For VGA see http://en.wikipedia.org/wiki/VGA_connector splines.jpg
Jan 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
I can't connect my data projector to Aspire One Pro Netbook. Why doesn't it show my powerpoint presentation?
just connect the vga cable to vga port of laptop and to the projector and in projector choose the source of display vga or pc mode and in laptop press f5 button or right click on desktop and choose the display mode lcd +monitor it will show you the display on projector.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | Acer Aspire One PC Notebook
I con't connect with lcd projector, xp windows
The video output will automatically switch to the data projector first when you power up the data projector first and then boot up the laptop.
When you power up the laptop first you can toggle the Windows image between the LCD screen and the video port/data projector by pressing the Fn key plus the F4 key. Pressing these keys each time will switch the display from LCD screen to video port only, to both LCD screen and video port, and back to LCD screen only.
May 14, 2009 | HP Compaq Presario V6000T Notebook
I have a Gateway mx3422 notebook. I cannot get the display to clone when I hook it up to a projector. The notebook screen goes black and the display shows on the projection screen.
hi!!!
there is a setting in your desktop
try go into control panel
then click on display then go to
settings and the
advance try locate the dual monitor settings
Oct 31, 2008 | Computers & Internet
Try fn key, And LCD/TV Or LCD/VGA usually marked on 1 of The number ( Numerical ) Or F Keys.
Remember to switch back before closing down, Otherwise the laptop will try to look for the projector.
The other option is to see, which device is set to boot first from the systems Bios.
Mike @ compurepair.
Sep 22, 2008 | Compaq Presario 700 470024-192 Notebook
Video projector from a laptop
You can connect the Projector to the VGA Port of the Notebook which is a Blue Port which can be seen at the rear of any desktop computer to which we usually connect the Monitor to.
The VGA Port will have 15 holes on it and should be in Blue colour.
You can locate the VGA Port at the Left side of the Notebook.
Locate the port according to the information available below :
http://h10032.www1.hp.com/ctg/Manual/c00726464.pdf
Refer to page number 14 (18 of 32) in the manual.
Once you connect the Projector to this port, hold the FN key and press F4 key once.
This wil get the Display on the Projector connected to the Notebook.
If you just want the display only on the Projector, hold the FN key and press the F4 again.
Now, if you want the display back on the LCD of the Notebook, Press the FN + F4 third time.
Hope this helps..
Aug 31, 2008 | HP Pavilion dv2000t Notebook
Automatic detection of lcd projectors to my hp compaq presario c700
try to set your resolution on your laptop, it have an option for proyektor setting, i've done it but now it displyed not horizontally but vertically, do you have any solution??
Jun 05, 2008 | Compaq Presario 700 470024-192 Notebook
Can't open Hardware setup
Hi Sam,
Is the correct Graphics driver installed onto the unit?
x-b-m
Mar 04, 2008 | Toshiba Satellite A60 Notebook
Compaq Presario Notebook Logo
385 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
