Question about Yamaha RX-V530 Receiver
How do i connect a turntable to my RX-V530 Yahama Receiver?
dsom
  • 56 Answers
SOURCE: Yahama receiver Rx-630 not working
The problem might be caused by two major circumstances. 1)Touching wires 2)Overheating. I suggest you unplug all wires connected to the amp then turn on the amp. If it gets turned on then we know that the problem is that you have touching wires. If there is a short circuit somewhere, get rid of it. The ventilation is another important issue that you have to pay attention. It simply causes overheating.
Posted on Jun 07, 2007
SOURCE: Connecting a Technics SL-BD20D turntable to a Yamaha RX-V463 Rece
After further research, I learned that I need to plug the turntable into a preamp before plugging it into my newer receiver. As with cassettes, record players are fading away. I ordered a preamp, but won't be able to experience success until it arrives.
Posted on Jan 17, 2009
lynchms
  • 93 Answers
SOURCE: yamaha rx v663 receiver, turntable input
What you will need is a phono pre-amp, then you can run into the receiver with a line level input to an empty audio input on the receiver, you can try Radio Shack to obtain one.
Posted on Feb 11, 2009
dunnbiker
  • 8546 Answers
SOURCE: hello, i have a prob.
If you really want the TV to have a high-res video feed from your receiver and the TV has the component video inputs, you'll could use that option for the video and it will look fine. On my HD TV I can't tell the difference between it and HDMI.
There are converters out there but they're electronic, not simply a modification of the cable to make it fit. I wouldn't bother with them...
My $.02...
I'm not a member of the run-all-video-into-the-receiver club, believing instead that the various signals would fare best if they went directly from their sources to the best electronics you have to handle them. Therefore, I run all video directly to my TV from the BluRay, DVD, Cable Box, VCR and all the best digital audio available from each of them directly to the receiver.
I see no benefit in running any signal unnecessarily through multiple devices (with possible cable and connection issues; and conversion anomalies) on its way to my eyes and ears.
My TV gets bare-bones composite video from the receiver just for the On Screen Display and basic analog audio from a DVD player and the cable box just in case I have Lo-Fi watching that doesn't need great sound. That way I don't even need to turn my receiver on for news, weather, documentary DVD's, etc.
Posted on Jan 12, 2011
  • 362 Answers
SOURCE: RX-V461 Yahama Receiver is hooked
double check input used on amp and make sure u use the auto format decoder fuction on your amp ok if it has none than turn it on optical digital ok that should work for you :)
Posted on Feb 10, 2011
Do I need to connect my older Fisher Turntable to a pre-amp before connecting to my Yamaha RX-V850?
No, you don't need a preamp if your turntable has a moving-magnet (MM) cartridge, it should work as-is! Happy vinyling =]
See page 27 of the manual:
Yamaha RX V850 User Manual Page 27
Aug 09, 2016 | Yamaha Rx-v850 Audio Video Receiver Black...
How to connect a turntable to Yamaha Rx-v630
If your turn table has a ground wire with the R and L wires then you can not connect it to this receiver. Unless you have a switch on the turn table that chooses between internal or external amp. If you have the switch, pick external amp and then run your R and L into your TV/CD input. Good luck to you.
Jun 06, 2016 | Yamaha RX-V630 Receiver
Can I use an Ipod Dock with a Yamaha RX V530 receiver?
WHY CONNECT THE I POD DOC WHEN YOU CAN CONNECT THE I POD DIRECTLY USING THE CORRESPONDING CABLES.
REGARDS.
Jul 03, 2011 | Yamaha RX-V530 Receiver
Yamaha rx-v530 volume maxes out when turned on
If you are using the remote to raise the volume of the unit, my advice is to forget that function, and turn volume manually. I had a similar problem with a Sony receiver and the solution was simply to put aside the remote. Remotes are infra-red based, and if you have other components with infra-red this can cause undesired interference and malfunction. Good Luck.
Flavio/BRAZIL
Jul 26, 2010 | Yamaha RX-V530 Receiver
Yamaha AV Amplifier RX V530
You might have your speakers shorted. Check the wiring at the amp and speaker terminals
Sep 09, 2009 | Yamaha RX-V530 Receiver
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
Jan 16, 2009 | Yamaha RX-V463 Receiver
Turntable connection
Yes, you'll need to purchase a PHONO PRE-AMP, and then connect the turntable to the pre-amp, and the pre-amp to the LINE INPUT of your receiver.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
May 20, 2008 | Yamaha RX-V361 Home Theater Receiver
No Image nec vt465 and yamaha rx v540
You must use the projectors menu to choose the type of input for video out. Your projector is capable of 720p or 1080i high def, but not through s video. If you want high def you must use the component output from your receiver to input on your projector. I hope this helps.
Jan 23, 2008 | Audio Players & Recorders
Open Questions:
Yamaha RX-V530 Receiver Logo
93 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
