Question about Philips Magnavox DVD/VCR Dual Player
Finalizing a disc so it can play on another dvd player
There is no picture when i play it on another dvd player
    Scholar:
  • 58 Answers
Video and sound are two different formats. Not all players support all sound and video. You may have a player that supports the sound portion of your disk but not the video.
Posted on Jan 18, 2009
My centrios edw8020 dvr records o.k. but won't play dvd on any other dvd systems
If the disc is not "finalized" it will not play on other DVD players. The steps to finalize the disc are part of the DISC Utilities Menu. under "DISC OPERATIONS". Choose "FInalize DISC". Instructions refer to finalizing DVD=R disc, so you may want to try this type of disc first and see if it works. Says It can be used as DVD-Video disc but results are not guaranteed. You can not edit disc after finalizing, only playback.
Jan 28, 2014 | Centrios EDW8020 DVD Recorder
My dvd player plays dvd discs ok. but when i use dvd burned on my computer shows no disc.the same disc plays fine on my computer
Some DVD and Blu-Ray players will not play a burned disc until it has been finalized. Finalize the disc on your computer then see if it will play. (Finaalizing a disc means it can no longer be recorded to, by the way.)
Aug 27, 2011 | Samsung BD-P1500 Blu-Ray Player
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
Jvc dvd/vcr player records from vcr to dvd but only plays back the dvd on the jvc DR-MV79 won't play on any other dvd players
Have you finalized the DVD in question? Unfinalized discs usually won't play in other machines. Is the DVD type compatible with the other dvd players? (Some may not handle DVD+R for example; it is an acceptable disc for the jvc DR-MV79.) Try a different brand and type of DVD. Check your other players supported discs.
To Finalize the disc, Menu > Setup > Disc Setting > Finalize (if needed set Disc Protection to Off).
I hope this helps.
Dec 25, 2010 | JVC Televison & Video
I just used my Sony minidv camcorder yesterday with a mini dvd +R disc and it worked fine. Turned it off while not in use and went to use it again later and it reads disc error. This is the second disc...
VIDEO mode You can play back the disc on most of DVD players if you finalize it.
VR mode You can edit, delete pictures, or divide movies on your camcorder However, the disc can be played back only on DVD players that support VR mode when you finalize it.
Apr 05, 2010 | Sony Video Cameras
MY DVD R DISC WILL NOT PAY IN MY DVD PLAYER - I HAVE A SONY DVD CAMCORDER BUT THE DISC WILL NOT PLAY ON MY DVD PLAYER
Please finalize recorded dvd disc in camcorder then it can be playback in any other dvd player.
Disc finalize option is available in camcorder disc menu.
Thanks.
Sep 09, 2009 | Sony Handycam DCR-DVD403 DVD Camcorder
WHAT DVD DISCS WILL PLAY ON THIS DVD PLAYER
Assuming you are not having an actual hardware problem with the DVD player or an incompatible format (e.g. HD video & non-HD player); you should know that when you write video to DVD-R or DVD+R discs, you have to 'finalize' the discs on the creating drive for them to be playable on a regular DVD player. (Note a finalized disc can no longer be written to. If the player can read DVD-Ram (and your creating drive can write to them), DVD-Ram discs do not need to be finalized.)
Dec 21, 2008 | JVC HR-XVS20 DVD Player/VCR
No finalizing dvd disc
Did you check to see whether the other player will play that type of disc?
Dec 10, 2008 | Sony Televison & Video
Recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Sep 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD will not finalize
I have a Zenith XBR413 that I have a problem with when I copy from VCR tapes to DVD-R discs. After I copy them, I can finalize the disc using the SETUP button on the remote and then choosing the very bottom disc icon at the bottom of the menu screen. It then leads you through the finalization procedure. But the disc will still not play on any DVD player but the XBR413
Jun 29, 2008 | Zenith XBR716
Philips Magnavox DVD/VCR Dual Player Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
