Question about Emerson ES2 CD Shelf System
PC connection Can I hook up my pc speaker output to the aux input on the Es2? If so what sort of connections do I need and can I use the ES2 speakers to listen to music from my pc? Thanks
  • 56 Answers
You definitely do. However, I recommend that you hook up your pc line out to the auxiliary input on the Es2. You only need an rca interconnector which has a 3.5 mm male stereo plug (hooks into pc line out jack).
Posted on Jun 23, 2007
How do u connect a sony speaker system to a pc?there are 2 speakers plus a sort of base unit
It is easy to hook up this 2 speaker setup first the ac power cord, then plug the green plug into the green audio output on the rear of your pc, there may be a wire connecting the 2nd speaker.
Jul 02, 2011 | Audio Players & Recorders
I hooked up the ion LP Dock to an analogue amplifier (which is hooked up to my LCD tv and outputs the sound through some bookshelf speakers) via the Phono input connections as per the instruction manual...
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
BUT, modern turntables like your come with their own preamplifiers, so they MUST be connected to a garden variety Line Level input like AUX (anything BUT Phono or it will overload).
http://www.needledoctor.com/Ion-LP-Dock-Turntable?sc=7&category=16189
"LP DOCK also has a line-level output for connecting to any home stereo with an AUX input"
As far as WHY your amplifier isn't making da music, that could be whole 'nother problem.
We'd need more details about it and the speakers to go there.
Feb 27, 2011 | Universal Electronics Ion LPDOCK USB...
I have a Vizio Flat Screen TV. I have speakers in all the rooms in my home. Can the TV be hooked up to the speakers with any success?
yes, the TV can be hooked to the speakers, but you will be needing a receiver (amplifier).
Check your TV, if you will have any earphone input space. If you find it on the TV, then it means job is half done.
Get a 3.5mm to RCA cord, connect the 3.5mm part to your TV's earphone space (if any), then connect the RCA part (Red and White) to input (Aux/Video/CD in etc) at the back of your receiver (amplifier) or deck, select the input (Aux/Video/CD in etc) on your sound system (receiver/amplifier) and sound should come out of the speakers.
Also, you can use this same method, but this time with a different wire which is RCA to RCA.
Connect the RCA (Red and white, to "Output" or 'Out' at the back of the TV, then connect the other part to the "Input" of your sound system (receiver/amplifier).
Good luck.
Dec 02, 2010 | Televison & Video
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
Connecting input & output on my TOA 900 series amp
http://www.toaelectronics.com/Manuals/P-906_12_24MK2.pdf.
Jan 07, 2008 | TOA Electronics P-924MK2 Amplifier
Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Oct 30, 2007 | Audio Players & Recorders
LOGITECH X530
Locate the Audio output on your TV and connect it to ur X530 Audio input. Locate ur Audio output (exa. AUX-OUT, MONITOR OUT, ETC..) on ur Home audio then connect it to ur X530 audio input. Goodluck
Aug 11, 2007 | Logitech X-530 Computer Speakers
Sony VPL - ES2 Colour problem
Isolate problem by using video and data(PC),if none of the imputs work call the vendor or Sony and sent it back for repair.
Aug 31, 2006 | Sony VPL-ES2 Multimedia Projector
Emerson ES2 CD Shelf System Logo
143 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
