Question about GE Profile JD968 Electric Kitchen Range
GE JB 968 FC CODE DURING SELF CLEANING
During self cleaning there is screeching sound from the near the door. Also the error code FC will come on, cannot reset oven to cook or turn off self clean. Disconnected the power overnight and as soon as we plugged back in the problem is still going.
  • bsburnett Jan 18, 2009
    Anyone know how to reset this thing??
  • 1,029 Answers
FC Problem with door lock circuit such as pinched wires between control and door lock switches on motorized lock circuits.
1. Check wiring and test operation of switches.
Posted on Jan 18, 2009
  • 10,515 Answers
Error code fc refers to :)
Problem of door locked circuit such as pinched wires between control and door lock switches on motorized lock circuits................
check wiring and test operation of switches...............
    Genius:
  • 1,913 Answers
Reset all settigns to factory defaults.
i think u have to take it to nearest service shop./
  • kishor khatri
    kishor khatri Jan 21, 2009
    yes
    go to printer sofiguration menu then u see reset menu then reset all settigns.then ssave .u can do it.thanks
F9 code on a GE Monogram zgp486ndr22ss stove. This is the everyday that begins heating then sets the code before it reaches the desired temp. How do I fix this
E MONOGRAM OVEN ZET1SM1SS F9 code after self ...
www.justanswer.com > Appliance
Question - GE MONOGRAM OVEN ZET1SM1SS F9 code after self cleaning for - DZ. Find the answer to ... f9 code means that your door lock mecanism is bad .or circuit board is failing. gst85 : .... WE HAVE A Whirlpool drop in range, model no.
GE wall oven ZEK938 error code F9 during preheat and
Nov 04, 2015 | Cars & Trucks
I have a GE self cleaning oven I want to clean. Do I need to take racks out, and am I able to use stove during this process
If you do not take the racks out they will discolor and not slide in and out as well as before. Do not use the stove for any other purpose during the cleaning process. Oven temperatures reach over 900 degrees during cleaning. Open a window to vent out the fumes from cleaning.
Oct 18, 2015 | GE 30" Self-Cleaning Freestanding Electric...
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Oven will not work.
This is what GE recommends for your oven:
“F—and a number or On models with a door latch, • The latch may have been moved, even if only slightly,
letter” flash in the display if a function error code appears from the locked position. Make sure the latch is moved
during the self-cleaning cycle, to the right as far as it will go.
check the oven door latch.
You have a function error code. • Touch the Clear/Off pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the range for 5 minutes
and then reconnect power. If the function error
code repeats, call for service.
May 18, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
During selfceaning cycle F5 and beeping occured, removed power and powered back on and it seems to be ok, however I haven't tryed the self cleaning yet.
possibly a door latch issue depending on your brand , this is common during self clean dont self clean unless u have to those ovens get close to 1000F so melting of some parts is inevatible.. did it flash f5 and then an error code like e1 or e2 that would direct us to possible more solutions, or it might blown a thermostat more likely on a wall oven and not a range.
Jan 28, 2010 | Ovens
My oven door is on locked possion and I can't open the door
have a GE oven with self cleaning. the lock selinoid that keeps you from unlocking the door during high temps and self cleaning had a melt down literally. removed back cover to get to selinoid and pried selinoid open to release lock.
Nov 15, 2009 | Ovens
Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
May 22, 2009 | Stoves Ovens
Oven door during self cleaning mode
hi there sounds like a faulty door interlock!!!!
have you tried just leaving the cooker on self clean as some models will lock them selfs.
Feb 29, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
GE Profile JD968 Electric Kitchen Range Logo
133 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
