Question about Pioneer PD-M406 6-Disc CD Changer
Pioneer PD-M430 will not recognize cds in changer
When the cds are loaded in the changer, the machine will not recognize them. it just shifts from one to the next like they are not there.
SOURCE: IT is Pioneer PD-M430 6-Disk CD changer
turn the cd, the silver side must be look down
Posted on Oct 14, 2007
  • 28 Answers
SOURCE: my Pd-f4o7 25 CD changer
Mechanical fault, monitor loading arm but most likely belts.
capital98
Posted on Dec 22, 2007
Duncan
  • 218 Answers
SOURCE: Pioneer PD-M430
If you can't put it back then the laser unit is no good anyway so it may be worth a try. I would not recomend super glue because it outgasses a substance that may cloud the lens. (that is how they use super glue to get finger prints from objects) Maybe use a thin film (very thin film) of rubber cement very carefully applied to the edge of the lens would do the trick. You must act fast because rubber cement cures so very fast. Another possible glue would be epoxy. It would give you a little more time before it starts to set up. Be sure you have the correct side up when you attach the lens, and be SURE that it is well seated in its socket so that you don't screw up the focus of the laser. Do a dry run or two with no glue to get the feel of what it takes. Don't forget to clean the "inside" side of the lens before you glue it in. You can clean the outside once it is glued in place. If all else fails you still are in a situation where you have to change out the laser assembly. Nothing ventured, nothing gained. Good luck.
Posted on Jun 10, 2008
  • 99 Answers
SOURCE: cd changer home stereo pioneer system
pioneer cd players have the common problem of losing their laser lens due to the glue that holds it in place going brittle over time. try shaking the player from side to side and upside down to see if you can hear the lens rattling about. if you recover the lens, very carefully slot it back in place and apply a tiny drop of glue (NOT SUPERGLUE) to the outside edge of the lens taking care not to get any on the focus area and leave to dry. all should be well after this. i find UHU GLUE in the yellow tubes do a lasting fix but don't use SUPERGLUE as the fumes will coat the lens.
hope this helps?
Posted on Jan 16, 2010
40longyears
  • 275 Answers
SOURCE: can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
Many Magnavox, Denon, JVC,
BMW 740 OEM and others.
Posted on Feb 28, 2011
My 6 CD CHANGER DRAWER WILL NOT OPEN
Remove the cover to expose innards and remove the cd's. Unit is no longer good.
Jan 01, 2016 | Car Audio & Video
I have a 2001 Honda Crv, the cd player keeps ejecting CDs before it has the chance to load them. The radio works fine, and I gave tried burnt and original disc CDs. Can anyone suggest a solution?
Are these CDs that you burned yourself? Older CD players won't recognize the audio file format of this kind of recording, only the established file format that typical retail CDs have used for years. In recent years, CD players have been developed to recognize more file types than just the old format; but with an older player like you have in your car, it wouldn't recognize what you were trying to play, as if you put a DVD in. It balks, and spits it out. You can burn CDs with the correct file format, you just need the appropriate software or file translator.
Apr 14, 2012 | Car Audio & Video
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
CDs go in the Upside Down position. Your PD M501 will accept PRW 1139, PRW 1141 and 163.
also:
BMW 740 OEM
May 15, 2010 | Pioneer PD-M603 6-Disc CD Changer
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
Applicable to:
also:
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Pioneer PD-M406 6-Disc CD Changer Logo
65 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
