Question about Toshiba Satellite Pro A210-EZ2202X Notebook
FROZEN IN LOGGING OFF MODE
My toshiba laptop is running into logging off mode,cannot shut down,cannot use mouse nothing.........it just keeps running as if it were shutting down, and I am unable to do anything.Please help. Brenda from BC CANADA
  • Anonymous May 01, 2009
    same problem. help!
  • 41 Answers
Go to control panel , sounds - under windows sign off choose no sound for this event.
If all else fails depress the power button until it powers off (longer than 5-10 seconds) or remove battery. after restart go into bios setup and reset default values and re-start your computer
Don
Posted on Jul 11, 2009
Laptop frozen on logging off mode, can't access anything
Have you tried starting in safe mode to see if it will boot that way? In case your not sure how turn the computer off then when off hit power on and just start pressing F8 over and over until you get the black screen asking about safe mode. You might hear some beeping while doing it dont worry about that. Choose start in safe mode with networking.Quick question is there any reason the lapshows the screen of windows starting vertically like that instead of the normal horizontal way from left to right? Just curious if you did that or thats new too.
Feb 05, 2013 | Computers & Internet
Toshiba Satellite A200 - Logging In
Please restart in the safe mode once.And run a virus scan after that turn off your laptop and turn it on again now don't go into the safe mode just start the windows normally,enter your password and see if you face the same problem.
Jun 24, 2008 | Toshiba Satellite A200-0ET00X Notebook
My Toshiba laptop is stuck in logging off mode. How can I fix this?
if you have a program running that is non responsive and try to shut down or restart, the computer will get stuck on the logging off screen. Often times if a computer takes a long time to do anything, it means you need to defrag your hard drive. Manually shut down the computer (you might have been pushing the Sleep button. If you can't figure it out, just unplug it and let the battery run down.) and when you restart it, go to the My Computer or Computer option, right click on your C drive, click on properties and a window should pop up. Click on the tab that says Tools and click on the Defragmentation option. The rest should be pretty self-explanatory. If nothing works. please try logging in as administrator in safe mode and doing a system restore.... please see Using Windows Vista System Restore :: the How-To Geek
Feb 28, 2011 | Toshiba Satellite Pro L300 Notebook
Put in correct password,but get logged off straight away
try logging into computer with safe more, when you turn on laptop, keep pressing f8 every secound to bring up a boot menu options, choose safe mode when it starts in safe mode log in with your acount goto control panel and acounts and delte password. or change it, then restart laptop and see how it goes. hope this helps
Dec 03, 2009 | Toshiba Portege 7200CT Notebook
Shutting down forever, just hangs there, cannot Control-Alt-Del back to restart or reboot. only function is to go into sleep mode w/ button; but coming back out of sleep just comes back to the...
you can kill this machine by pressing the power button in for more than 10 seconds. it should shutdown instantly.
If you have automatic update on this can delay your switch off time as it installs programmes after logging out. i hate updates so i turn them off.
when you get it back up and running ask it to do a disk check of files and repair. It may ask to carry out this during next boot up. this is fine.
You may have linked files etc and this will sort them out for you. A manual run of the file CHKDSK /F is needed
If this helped you vote for me
AndystUK
Aug 31, 2009 | Computers & Internet
Toshiba laptop frozen on logging off screen; won't switch off, nothing working. Tried esc, cad, now trying to run down battery. Any ideas?
I unplugged the a/c adapter, took the battery out then plugged in again and everything was fine. Otherwise, when I tried to turn off it would just sleep. But that's the way I solved it.
Jun 29, 2009 | Toshiba Satellite Pro A210-EZ2202X...
Mouse frozen on Laptop
try holding down Alt and press either F5 or F7
keep us informed please
regards
Dec 22, 2008 | Toshiba Satellite A105 Notebook
Toshiba, when i start the computer. it says toshiba tempro accounted a problem, computer logging of, and then it shuts down.
There are a myriad of problems that could have resulted in this.
1. A virus has shut down your system
2. Memory has gone bad
3. Last software you installed has corrupted the hard drive
Possible solutions:
1. When it is coming up – hit F8 (over and over again) till the menu comes up :
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
See if you can get in safe mode. IF NOT – repeat these steps, and instead of clicking on Safe Mode – Click on “Last Known Good Configuration”
IF THAT does not work:
Insert your recovery CD and see if you can boot up to that.
If THAT still does not work, you have a hardware problem, either memory chips (RAM) or your Hard Drive.
Jul 17, 2008 | Computers & Internet
Problem to log in.
Start up in safe mode pressing F8 on boot up and select safe mode. When in the system under administrator there will be option for you to delete the password on your account. Re boot then enter again with no password.
Feb 22, 2007 | Toshiba Satellite M100 Notebook
Toshiba Satellite Pro A210-EZ2202X Notebook Logo
151 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
