Tv code for Goodmans GTV26WLCD for sky remote
  • 146 Answers
SOURCE: sky code for a goodmans gtvl19w17 hdv
Try this : Turn TV on, point remote away from TV, press TV button on your SKY remote...hold down SELECT and the RED key together for about two seconds, until the red light (LED) on the remote blinks twice...key in the remote code for your model of TV on the remote keypad ( for Goodmans, try 065, or 0335 ) then press SELECT button ( the LED should blink twice to show code accepted ) press SKY button to exit. point remote at TV and test.....Job Done . !
Posted on Dec 14, 2007
chrispurs1
  • 372 Answers
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Posted on Jan 20, 2008
SOURCE: Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Posted on Aug 04, 2008
SOURCE: gu15wdvdt tv .sky remote code
posted by mike 13 aug 2008
I have just had sky installed and the code for grundig gu15wdvdt is 1239
Posted on Aug 12, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
Does anyone know the sky remote code for my goodmans GTVL19W17HDF ? please
Hello
Setup codes for Goodmans TV with Sky remote are:
065 064 100 588 285 037 292 544 207 318 363 399 402 515 527 392 371 245 563 297 584 060 103 263 508 063 616 055
527
055
402
563
662
696
652
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5*Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 25, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
I need a sky remote code for my gtv34t7sil
The SKY remote codes for Goodmans TV are as follows:
Goodmans 0335, 065, 064, 100, 285, 037, 292, 544, 207, 318,
Work through each one in turn to find which one provides the best result.
Regards,
sjstore2
Dec 18, 2010 | Goodmans Televison & Video
Goodmans LD3266D TV - need the code to work volume control on my sky HD+ revision 8 remote control
Well first you can try - 065, 064, 100, 285, 037, 292, 544, 207, 318, 363, 399, 402, 515
if none of the code works for you then please follow the below link to know how to search your sky remote code -
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
also check the below link -
http://www.skyuser.co.uk/tools/remotecodes/index.php
Good Luck!!
Mar 13, 2010 | Goodmans W280NS Television
CANT FIND THE CODE TO TUNE IN MY SKY REMOTE,MY TV IS A GOODMANS LD3266D
On your sky remote press interactive-skyactive-help-set up my remote follow instructions. If your Model No not on list keep checking for updated info. If no joy then contact goodmans customer services.
Sep 16, 2009 | Goodmans Televison & Video
No instructions for a goodmans remote
there are a few numbers for a goodmans tv (the codes are for gemini 6 in one)they all enter 3 digits
002 004 009 027 028 051 068 093 111 115 127 153 169 171
hope that helps
May 02, 2009 | Gemini 1 Device Universal Television...
Unable to tune my Sky Remote to my tv
panasonic 37in can't pair sky remote with tv
Jan 09, 2009 | Televison & Video
Sky code for a goodmans gtvl19w17 hdv
Nov 19, 2007 | Goodmans W280NS Television
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
