How to upgrade bios - Computers & Internet
  • 1 more comment
  • sacharsahil May 11, 2009
    I DONT KNOW FROM WHERE TO GET NEW VERSION OF BIOS WHICH IS COMPATIBLE WITH MY MOTHERBOARD
  • Casey Craig
    Casey Craig May 11, 2010
    what is the model # and brand of the computer
  • rebelyes1 May 11, 2010
    you need to know what is the exact version of you bios now, then we can download a new one and "flash" your bios. let me know if you need help with getting the info on your current bios and then we will proceed to the second ste...
    Habit-Forming:
  • 156 Answers
You need to get the binary file that contains the BIOS data from the computer/motherboard vendor. You also need a utility to write the contents of the BIOS data file to the flash memory that will hold the new BIOS data. You might need to have a blank floppy disk or 2 to do this.
Posted on Jan 18, 2009
Upgrade software from windows 7 starter to windows 7 ultimate need bios password
Strange. Shouldn't need BIOS password to install software. Be that as it may, the only person that is going to know that is the person who set it. None of the Major manufacturers actually set the BIOS password when they sell systems. If you have no way of finding out what it was set to by asking the previous owner your best chance to get it is to open the case after disconnecting the power and removing the BIOS or CMOS battery. This will rest the Bios to factory default.
Jun 16, 2011 | Computers & Internet
How to update my asus p4sgl-mx motherboard bios
"BUPDATER BIOS Upgrade Procedure" read the Instructions/Procedure from ASUSTEK
Caution:
Updating your Mainboard BIOS is not for the novice, any errors ie.Wrong Bios versions or power failure occuring during your Bios process may render your mainboard useless!!! Do it at your own risks.
Hope it helps.
Jun 02, 2011 | ASUS Computers & Internet
Drive A media error bios checksum error
your current bios is corrupted since the check-sum that was generated when your bios eprom was flashed with your current bios version doesn't match the check-sum that is generated as now, meaning that your bios changed for a few bits. you can fix this problem by re-flashing your bios with a good ROM file that you can download from your computer maker site or your motherboard bios maker site, also upgrading your bios with a newer version will take care of the issue as well.
Mar 07, 2011 | Computers & Internet
My raid controller has not install
Your RAID controller is managed by the RAID BIOS on the motherboard. Depending on the motherboard manufacture, you should be able to boot into the RAID BIOS to make adjustments to the RAID array.
Turn the machine off then turn it back on. Look for key combinations of Ctrl+R or similar to access the on-board RAID BIOS. Refer to the manufacture documentation for OS support or BIOS upgrades.
Mar 05, 2011 | Computers & Internet
Where can i download free acer aspire bios upgrade for 5738z for wondows 7 os.
on this page
http://www.acer.co.uk/ac/en/GB/content/drivers
select Notebook -->aspire -->Aspire 5738z and go
click on bios and you can download latest bios for your lap.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Feb 27, 2011 | Computers & Internet
I try update my bio on my ao0751h netbook acer, and doesn't successfully, now my netbook doesn't turn on. How i recovery a bios?
Solution 1: Boot-block BIOS
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive.If you have a PCI video card,you won't see anything on the screen because the boot-block BIOs only supports an ISA videocard.
Award: The boot-block BIOS will execute an AUTOEXEC.BAT file on a bootable diskette. Copy an Award flasher & the correct BIOS *.bin file on the floppy and execute it automaticly by putting awdflash *.bin in the AUTOEXEC.BAT file.
AMI: The AMI boot-block BIOS will look for a AMIBOOT.ROM file on a diskette. Copy and rename the correct BIOS file on the floppy and power up the PC. The floppy doesn't need to be bootable. You will see the PC read the floppy, after about 4 minutes you will hear 4 beeps, this means the transfer is done. Reboot the PC and modify the CMOS for your configuration.
Solution 2: Get a new BIOS chip
  1. Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufactures send them for free.
  2. Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or Bios World
Solution 3: Hot-swapping
Note: I'm not responsible for any damage this method may do to you or your computer !
  1. Replace the corrupt chip by a working one. The best option is to take the working BIOS chip from a motherboard which has the same chipset although that's not absolutely necessary. It just has to give you a chance of booting into DOS. Before pulling the working BIOS chip out of it's original motherboard, set the System BIOS cacheable option in the BIOS to enabled.
  2. After you have put the working BIOS in the motherboard with the corrupt BIOS boot the system to DOS (with a floppy or HD).
  3. Now replace (while the computer is powered on) the working BIOS chip with the corrupt one.
  4. Flash an appropriate BIOS to the corrupt BIOS and reboot.
Solution 4: (for Intel motherboards)
  1. Change Flash Recovery jumper to the recovery mode position (not all products have this feature)
  2. Install the bootable upgrade diskette into drive A:
  3. Reboot the system
  4. Because of the small amount of code available in the non-erasable boot block area, no video is available to direct the procedure. The procedure can be monitored by listening to the speaker and looking at the floppy drive LED. When the system beeps and the floppy drive LED is lit, the system is copying the recovery code into the FLASH device. As soon as the drive LED goes off, the recovery is complete.
  5. Turn the system off
  6. Change the Flash Recovery jumper back to the default position
  7. Leave the upgrade floppy in drive A: and turn the system on
  8. Continue with the original upgrade
Feb 03, 2010 | Computers & Internet
I need driver for Phoenix - AwardBIOS v6.00PG
"AwardBIOS v6.00PG" is not enough information to find a BIOS upgrade. What you need is the maker and model of motherboard that you have. This will be written on the board itself (usually around the center), so if you open the case you can read it.
If you don't want to open the case you can also download SystemInfo (for free), run it, go to the Motherboard section and it will tell you the motherboard maker and model. With that we can go to the maker's site and find the BIOS upgrades available.
Also, if it is not a custom built PC, you can go the manufacturer's sire (HP, Dell, etc) and go through their downloads section to find BIOS updates.
SystemInfo - http://www.gtopala.com/download/siw.exe
Jan 28, 2010 | Computers & Internet
When i tryed to upgrade my windows 98 to 2000 Although during the final steps of the setup the computer resarted and it stared over again then again and again?
This is due to either incompatible BIOS settings or incompatible hardware. Make sure all of your hardware is compatible with Windows 2000 before upgrading. If so, then check all BIOS settings to ensure compatibility.
Jul 20, 2009 | Intel Computers & Internet
How to upgrade from Vista Basic to Vista Premium.
You need a Vista premium disk to upgrade to Vista premium.
Just instert the Vista premium disk and start the installation.
If installation does not start, you will need to boot from setup CD, sometimes you have to change the bios boot sequence in bios settings, to start the installation from CD.
Nov 16, 2008 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
103 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
