Onida lcd 32 inch xaria got switch off and now blue power light is flickering for some time but tv is not turnning on
SOURCE: Wharfedale TV power problems
got a 32 inch wharfedale tv from argos also and it seems to boot up and then shut down and just loops, if i keep unplugging it i can sometimes get it on but with a high pitch wailing, only 15 months old, gutted!
Posted on Oct 07, 2008
SOURCE: samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Posted on Dec 23, 2008
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
  • 3 Answers
SOURCE: Samsung 32 inch LCD delay in start up
I had a technician fix this exact problem today it is the POWER SUPPLY the TV is not getting enough power to the main board, i have been searching for weeks and no one ever post a solution here it is guys get them fixed $200 only
Posted on Apr 24, 2009
fixyathing
  • 341 Answers
SOURCE: i have an onn 32 inch lcd tv that will not turn on
Most probably a switching power supply problem. Have it checked by a qualified technician.
Posted on Aug 16, 2009
Saound OK no light on Onida Xaria 22 LCD
Check and rectify fault at its back-light inverter board. Contact any service technician. This is not a user repairable fault. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 29, 2014 | Televison & Video
ONIDA 22"LCD
There could have been a power supply failure.
Jan 10, 2014 | Televison & Video
I having problem on onida xaria lcd tv that tv is on standby mode but wouldn't turn on
Change the battles of your remote and then check if not then its need to be service
Dec 16, 2013 | Televison & Video
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
I wish to know the input voltage given to Onida 32 Xaria board
Only the correct replacement board should be installed--another even if similar looking will not work.
May 27, 2012 | Televison & Video
On/off switch not working
replaced the power supply board
Feb 18, 2009 | Vizio L32 32 in. LCD HDTV
Tv won't come on
check the relay drive transistor
you need a qualified tv repair personal to check tv
Jan 15, 2009 | JVC AV-32D305 32" TV
Lcd not turning on
May i know is it the power led light blinking or just steady?
Jul 20, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
