Looking for replacement speaker for califone 1450k
2 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: Califone 1450K
Ya, this is a tough one. If it was on it's side, and not handle properly, something may have come loose and caused some damage inside. If you have absolutely no power, then more than likely the power transformer fried. Not much else in these things that could have caused such an issue. At this point, you have to decide whether it's worth getting repaired, or buying a working used one. They go on ebay for about $30-50, which is much cheaper than getting it repaired. Transformers for these units run around $20-30, then you have to tack on labor, which will be in the 40 min range - that's if its the transformer. But I do understand if it has some personal value, so that is something to consider. Hope this helps some. - Justin DJPROAUDIO
Posted on Sep 02, 2007
Repair a Califone 1430K record player plug & speaker
There was a time when I could say "Go to Radio Shack " and they would have all you need for your record player. To answer your questions about the rumbling, that is lack of a ground in the plug, cracked speak, and noise / sound coming out of player is being picked up by needle and coming back out of speaker. Solution: cut the old plug off and replace with 3 prong plug (hardware store). Look on back of record player and see if it has the info (watts and ohms) about speaker. If not, the speaker needs to be removed to get info. You can search online for a replacement speaker or your local guitar center has replacement speakers ( Call first ) P.S. If the record player has a lid, bring it down after you start record, keeps out outside noise.
May 18, 2016 | Audio Players & Recorders
Platter not spinning
Some turntables only move when you move the arm to the record. If that doesn't work and you have read the set up instructions correctly, as it's new contact the maker or the place you purchased it from. I'm certain they will help.
Mar 22, 2014 | Califone International Audio Players &...
I have a Califone 1410 K and would like to hook it up to my stereo receiver. Can anyone tell me if this will work and, if so, what kind of cord I need for the external speaker jack? Thanks so much!
a big plug jack would work, like the kind used for guitars to amplifiers. I have one a friend of mine made for me (he works in a music shop) and it goes in the "external speaker" hole to the amp pretty simple.
Jan 08, 2013 | Califone International Audio Players &...
I have a Califone 1620 model economy classroom phonograph in need
Probably a bad relay switch. Open up the turntable. Identify the motor that spins the table. Follow the wires of that motor to, perhaps, some type of little circuit board with a relay. I have a Backley-Cardy 322-487 classroom phonograph which uses a Califone 1620 amp and a BSR turntable. To get the table to spin, you have to move the tone arm. Mine doesn't move and I'm in the process of replacing the faulty relay that is the problem.
Sep 30, 2009 | Califone International 1030AV Turntable
Trying to fix an old record player - Califone. It seems to be making a scratchy sound even though I have replaced the needle. It almost sounds like when the two wires from a speaker touch... same...
May be the "winding" on the speaker. If it has got damp at some point(you may not notice any on the casing) the cardboard tube that the coil is wound around swells and "rubs" in the speaker. Thus producing a scratching sound. Try connecting to another speaker, just to test and if it sounds fine then that is what it is.
May 14, 2009 | Califone International 1030AV Turntable
Adjust pitch on a Califone turntable.
This one is actually fastened from underneath (inside). You need to open the player up and you will see the usual C shaped fastener on a cleat near the motor assembly. Most old direct drive record players have a C pin around the spindle that you can unfasten (pry with a twist) with a screwdriver. Irealize you figured this out yourself, but I'll take the guess work out for someone else... yeah..l you gotta take it apart!
Feb 15, 2009 | Califone International 1030AV Turntable
Califone 1450k
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!1
Nov 08, 2008 | Califone International 1030AV Turntable
Ax-12 computer mic
The Califone AX-12 has a 3.5mm connector on the cord. This should plug into the sound card on your computer... usually found on the back of the computer in the same general area that the speakers plug in.
Jul 14, 2008 | Califone International (AX-12) Consumer...
Califone 1450K
Aug 02, 2007 | Califone International 1030AV Turntable
23 people viewed this question
 Grubhead
Grubhead
