Question about Whirlpool Duet GHW9150P Front Load Washer
Washer will not turn on
Whirlpool Front-load GHW 9100LW1
Thawed out the water line, machine started to fill with water immediately...even without it being turned on. Power is on to outlet but washer will not turn on. Pressed control lock/unlock, but nothing happens.
We had to turn the water off to the machine because it keeps filling up with water
    Guru:
  • 462 Answers
You have some scale or something keeping the water fill valve open most likely. If it still tries to fill unplug the machine if it still tries to fill do the following. Remove the fill valve and disassemble it. If you see the dirt or rust flush it out when it looks clean reassemble it and before you attach the hoses put them in the washer and turn them on to flush out the lines then reattach hoses and try it.
If this helps you please rate me with as high a retign as possible. If not please restate your problem and help me understand better what trouble your having. Thnks for using fixya and good luck.
Posted on Mar 24, 2009
Just bought a front load whirlpool wash machine. when i turn it on it locks door then unlocks door, it does this 2 to 3 times then the washer fills with some water only spins about 3 times then it waits...
This washer will stop and start a number of times during fill as it is sensing how much water it needs. Also you must hook both water line up and have both on. Also you must use HE soap and very little of it.
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water goes into the washer even when the washer is off
Yes , the valve is stuck. take top cover off to get to it by removing 3 or 4 screws from top rear and replace.
Phil
Apr 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool duet front loader
Washer should fill, remove hoses, check screens in hoses and or valves on machine for clogs. Verify water valves at the source are turned on. If all this checks, you need new valve installed on your washer.
May 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
116 people viewed this question
Dan Webster
Dan Webster
Sal De
