Question about Roper REX4634KQ Electric Dryer
Cleaning lint Every other dryer I have ever owned I cleaned the lint out from over the heater once a year. I can't believe I have to spend money for a repair man once a year now because I have a roper dryer. How do I make my way to the heater so I can avoid a build up ?
  • 198 Answers
Your Roper dryer is made by Whirlpool, there is no reason to clean lint from around the heater, very little lint collects in that area. Every once in a while you can take the front off by removing 2 screws from under the lint screen, then pry up the top and there are 2 screws that hold the front on inside facing out. After removing the front you can vacuum inside below the drum.
Posted on Jan 18, 2009
Crumbly black flecks in dryer, on clothes
first off get a new lint filter part number WE18X53 and it's around 20 to 30 dollars depending on where you buy it,now when you say you cleaned the dryer do you mean you cleaned just where the clothes go into or did you unplug it and take it apart and clean it out?if you look at the inside back wall you'll see holes,on g.e. dryers lint builds up behind the drum and the heat shield,you can try vacumming the lint out of the holes but the best way is to pull the drum,clean the back of the drum out where i was just telling you about,vacing out the cabinet where the motor is and then blow off the motor and cabinet with the shop vac the other side of it blows air and clean out the duct where the lint filter is and clean out the door,then blow out the vent line,if the line is long you can remove it from the dryer and blow it out with a leaf blower,it sounds like the dryer never has had a clean out,i know you most likely will have to call some one in to do this but for now with a shop vac set it up to blow,remove the lint filter and blow all the lint out of the duct,blow it for a few seconds the vac up the lint and do it again until it's clean,then vac the back of the drum,if you put a light in the drum you can see the lint through the holes,you can try blowing through the holes to lossen the lint and then vac it out and see if that helps but the dryer has to be taken apart and cleaned so you don't have a fire,this should be done at least once a year if it's gas and once every 1 1/2 to 2 years if electric,this way your clothes will dry on time and mostly so you don't have a fire. also when it's pulled apart you can check all the parts to make sure nothing has to be changed out like the rear bearing and rollers and pulley,also check the heater to make sure it's not sagging after a while on electric dryers the heater coils can sag down and short out,when you have it apart you can tighten them up and bend them up into shape again,hope this helps and good luck with your machine.
Sep 08, 2012 | GE Dryers
My dryer shuts off mid-cycle. It heats up and the drum turns but it will shut off mid-cycle. Sometimes it will re-start immediately and sometimes it takes about 15 minutes before it will start again. Any...
Hi and welcome to FixYa, I am Kelly.
There are only 2 causes for this....
restricted Air flow or
broken / damaged blower fan wheel
- Start by pulling the lint filter and washing it with vinegar and water then soap and water to remove any dryer sheet particulate that blocks what appears to be clean filters.
- Next clean out every dryer passage you can access.... use a vacuum with crevice tool and a "U" bent wire coat hanger to get all of the lint out of the lint filter area DEEP down inside....
- Then pull off the dryer duct from the rear of the dryer and clean the internal ducting of the dryer.
- After you think you are done cleaning... reverse the vacuum airflow to pressure... if you see lint floating in the air your not done cleaning. Start over...
- Next follow the duct work all the way through to the outside wall and OUTSIDE. Clean the dryer vent on BOTH sides of the vent flapper outside the home.
- Before hooking up / re-connecting the dryer ducting again to the back of the dryer... turn on the dryer. Use the back of your relaxed hand over the duct / vent outlet of the dryer... the air flow must be strong enough to push a relaxed hand / wrist gently away from the hole.. IF you do not have this kind of air flow after your cleaning session... the most probable failure is the hub of the blower wheel / fan is cracked allowing the blower to spin on the motor shaft.
I think once you get things cleaned up... your dryer will return to normal again. My last comment.... and I am being honest. I have made a lot of money... cleaning out dryer duct work after the customer said they had cleaned it very well. I finished the job they started.... and got paid for doing so. I am passing on 40 + years experience here for free because I believe in helping people help themselves..
Thanks for choosing FixYa,
Kelly
Apr 17, 2011 | Dryers
Dryer heats and runs but clothes are not completely dry. the lint light comes on. have cleaned lint out of dryer including behind and underneath
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 21, 2011 | Bosch Axxis WTA 3500 Dryer
Clothes come out mostly dry, but need to run a 10 or 15 more minutes to completely dry. Towels need 2 drying cycles. Lint filter is clean. Lots of lint behind dryer and I notice a lot of lint on...
you need to clean out the dryer.somewhere lint is blocking the air movement.pull off the vent line,if it's long blow it out with a leaf blower,then clean out the duct that the lint filter slides into and vac out the cabinet where the motor is.if it's gas you should do this once a year electric once every two years.
Feb 17, 2011 | Dryers
How do I clean the lint out of the system? My cloths aren't drying. It takes 2 cycles to get the cloths dry. I cleaned out the lint trap, but it is still doing it. Is there a web page or instructions...
heatman101
Oct 13, 2010 | Frigidaire GLER642A Electric Dryer
Clothes take at least 2 hours to dry. cleaned out vent and all lint in lint trap and squirrel cage motor
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 24, 2010 | Maytag Dryers
Kenmore series 90 electric dryer: exhaust air is
that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
Dec 18, 2009 | Kenmore Dryers
Dryer is making my clothes smell like smoke.
Clean out the dryer vent exhaust system. Check the gas burner for a clean blue flame with white tips. Air shutter on the gas burner may need adjusting.
Clean out any lint in the dryer cabinet.
Aug 30, 2009 | Whirlpool GGW9250PL Gas Dryer
Bosch WTM C3300 Dryer
I don't own this model of the Bosch dryer, but my guess is that your hot air flow path is partially blocked with lint or something else. Our heating/air flow element was blocked with a errant latex club hit the elements. I cleaned the flow path and removed the heater obstruction with good results for nearly a year to date.
Oct 25, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Hotpoint tumble dryer condenser
have you clean the whole dryer air duct?. try cleaning all the walls for lints and check the blower wheel. it could be filty with lint and decreases the airflow there by increasing the temperature too much to blow those limit fuses. you would not believe how much dirt and lint we collect on those ducts. check also the exhaust hose at the back, it could hinder the flow of air if its dirty. and too many turns. as much as possible, limit the turns of the hose.
Feb 12, 2008 | Dryers
Roper REX4634KQ Electric Dryer Logo
90 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
