Question about HP Photosmart C6180 All-In-One InkJet Printer
Ink system Failure Error Oxc18a0001
Puat in new black in cartridge and this error occurred. I have tried all fixes at HP site. Shut down machine. took out all ink. rebooted. no fix.
Also tried pressing OK, cancel, black and color button at same time as power off. waited. restarted. no fix
  • 2 more comments
  • grover1223 Jan 18, 2009
    Just to fit HP
  • gingerm Feb 02, 2009
    I replaced cartridges with hp ink cartridges and the printer now says ink system failure and it refuses to budge. I can not find the printer documentation. Need help. ginger
  • Anonymous Feb 18, 2009
    ink failure oxc18a0001
  • Thomas F. Schneider May 11, 2010
    Is the cartridge you installed made by HP, or just to fit HP?
Hold the number 9 key and the key down at the same time, then pull the power cord. Then put the power cord back in while holding the 9 and # key. You will lose your settings, but the ink system failure message should go away.
Posted on Mar 11, 2009
See posting on 8/23/07 by Egizianos. I had same problem and this solution fixed it.
Posted on Mar 30, 2009
    President:
  • 2,692 Answers
Return it and and get an HP one.
Posted on Jan 18, 2009
Oxc18a0001 on a HP 3110 keeps sending an error mesage and wont let me copy,fax,print so it is pretty much useless
Welcome to Fixya
Try to reset the printer. Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the printer off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
Please click here if you need further professional assistance.
Thank you for choosing Fixya!
Oct 16, 2011 | HP Photosmart 3110 All-In-One InkJet...
When the printer is turned on it states: ink system failure. Unable to print. Refer to printer documentation. Error Oxc18a0001.
possible causes of this:
  • loose or improperly installed ink cartridge
  • damaged cartridge
  • dirty print head
Solutions:
  • check cartridge connection, try to remove and reconnect
  • replace damaged cartridge
  • clean printhead using the printhead cleaning utility software of your printer
Oct 21, 2010 | HP Office Equipment & Supplies
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Jul 16, 2009 | HP Photosmart D7460 Printer
Error message oxc18a0001 ink system failure
Go to HP website, I recall some info there on this
Apr 25, 2009 | HP Photosmart 3310 Printer
HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Dec 04, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
281 people viewed this question
Ben Johnson
