Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis he 11027062603 water pump - Kenmore Oasis HE 27082 Top Load Washer
5 Suggested Answers
  • 59 Answers
SOURCE: if the washer machine kenmore elite oasis he is
The drain pump evacuates the water from the tub and down the drain pipe. There is only a solenoid valve assembly to let water into the washer.
Posted on Feb 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite oasis squeels when filling with water
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: how do i get the
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Posted on Sep 26, 2010
  • 102366 Answers
SOURCE: I need an owners manual for my Kenmore Elite Oasis
You can view/download the manual here.
Posted on Oct 28, 2011
Has my Kenmore Elite Model 110.27082603 been recalled?
I am trying to find out if my Kenmore Elite Oasis HE model # 11027062603 has been recalled. Thanks
Mar 28, 2013 | Kenmore Oasis HE 27082 Top Load Washer
I have a kenmore oasis # 110.27087603 the machine stopped working. i emptied the water and it begun working until it stopped at 21mins into the wash cycle. i emptied the machine and it did the same thing....
most likely a drain pump issue or the main board is not telling the pump to run. board is pricey for a test but the pump could be stopped. if you do not hear the drain pump running, try replacing it, if the pump hums but no water moves, you need to check intake . pump is underneath washer on the right. the left is a recirc pump and is not interchangable.
Jan 03, 2012 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
My kenmore oasis washer has started leaking out water and flooding my floor. have you had any other complaints about this problem and how to fix it.
first of, you need to find out where the water is originating from, pull washer away from wall and look for water dripping. usually water leakage starts from pump. on this washer there is a circulation pump and a drain pump on bottom left and right side. check all hoses and enure that there is no pin holes started
Aug 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
If the washer machine kenmore elite oasis he is draining water is it a water pump or draining pump?
Feb 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
KENMORE WASHING,wATER IS LEAKING FROM THE BOTTOM NOT THE HOSES
Possible circulation or drain pump leaking or associated hoses. See page 11 Oasis Tech Sheet
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 25, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I need to know how to remove the water pump on a kenmore elite
Hi, get me the modle# and I can get you through this. THaks
Vic
May 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
24 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
