Question about HP Photosmart C3180 All-In-One InkJet Printer
My daughter has given me her printer HP Photosmart C3180 without the directions and I don't know how to put in ink cartridges
    Problem Solver:
  • 18 Answers
Posted on Jan 18, 2009
    President:
  • 2,692 Answers
All the info you should ever need to know right on the HP support website for your printer:
http://h10025.www1.hp.com/ewfrf/wc/product?product=1146331&lc=en&cc=us&dlc=en&submit.y=5&submit.x=6〈=en&cc=us
My daughter loader a black ink cartridge without removing the cellophane tape. The printer is now flashing the check black ink cartridge message. We have tried reloading the cartridge properly. Still not...
here is what you do .
1.first unplug the printer ,and shut down you computer .
2.then open then printer cartridge area. remove both color & black cartridges
3.check the black cartrage ( the head of cartrage is it damaged ,,, i mean it should just be like glass surface no ups and downs .. if the cartrage is ok then (youdont have to change it )
4.power on you printer without loading any cartridge .
5.now unplug again and insert cartridge only black .and plug your cartridge .( note PC will turn off in entire procedure) and let your USB cable out of the printer
6.turn on your PC when you see the desktop insert the USB cable. and let the process happen ..!
7. give out print command
i hope that will solve your problem !
do vote /write if it helps you
Apr 04, 2011 | HP Photosmart C3180 All-In-One InkJet...
The following print cartridge is not intended for use in this printer for HP-Photosmart C3180. Cartridge on Right . Not able to use Compatible ink cartridge for this model? any solutions?
The ink cartridges that can be used with this printer are HP92(black), HP93(tricolor), and HP99(photo). You can use other brands that cross over to the HP numbers but they would be the only cartridges you should use for proper operation.
Sep 26, 2009 | HP Photosmart C3180 All-In-One InkJet...
Photo ink
Remove the tab from your photo cartridge. Power the printer. Open the printer cover and the cartridges should move to be accessible. Remove the color cartridge: move it gently toward you and remove. Insert the photo cartridge. Close the printer cover.
Jun 13, 2009 | HP Photosmart C3180 All-In-One InkJet...
Want to know where u put the photosmart ink in printer
Open the print cartridge door. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again. IMPORTANT: The device must be turned on to insert cartridges.
You can see the location and proceedure to change the ink cartridges on page 14 of the manual (found here: http://h10032.www1.hp.com/ctg/Manual/c00694908.pdf). Sometimes a picture is worth a thousand words <grin>.
Hope this helps,
Chris
Mar 23, 2009 | HP Photosmart C3180 All-In-One InkJet...
Ink cartridge
Black HP 92
Color HP 93
Photo HP 99
Jan 11, 2009 | HP Photosmart C3180 All-In-One InkJet...
How do I install ink HP photosmart c3180
Hey DDD,
It looks like HP put together an animation to help with replacing the ink cartridges. I know you are just trying to install them for the first time, but it might be helpful:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00652671&cc=us&lc=en&dlc=en&product=1146331
Also, since you are just setting up the new product, double check that you've removed all the packing material and tape from the cartridges. I've made that mistake before ;-)
Cheers,
_K
Jan 08, 2009 | HP Photosmart C3180 All-In-One InkJet...
Problems with the hp c3180 all-in-one printer
Did you clean the contacts inside the printer as well as the ink might be built up where cartridge contacts touch the printer contacts in the housing. You have to be quite careful here as there is a small metal spike which grips the printer and you do not want to push this into the contacts in the housing. Just get some damp tissue and rub it over these contacts to clean up any residual ink( turn off the printer first)
Fred
Jun 14, 2008 | HP Photosmart C3180 All-In-One InkJet...
Ink cartridge
Go to www.hp.com
Click on Support and Troubleshooting
Type C3180 for Product press Enter
click on Set up and Install
Click on install the Print Cartridges
Mar 04, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
47 people viewed this question
Ben Johnson
