Question about Amana AOCS3040SS Electric Single Oven
WHIRLPOOL OVEN +G2P61F
My circular heating element is not working oven is not heating at all, could you please tell me how I go about repairing it.
Thank you
  • 1 more comment
  • priestleyk4a Jan 18, 2009
    Thanks a lot I will try it, much appreciated xx
    Hi again, could you please tell me where I can purchase the element for my oven?
  • Anonymous Mar 26, 2014
    oven is from the late 1970's
  • Amana Master
  • 3,463 Answers
Remove cover at rear of oven compartment, there you will see the element.
Undo fixing screw(s), carefully pull the element towards you, remove wires, be careful not to lose them inside ,and fit onto new element.
Refit element and rear cover.
Plz rate my solution.
Thanks.
Posted on Jan 18, 2009
My whirlpool single oven G2p61F/01 will not heat up the the grill still works though any ideas ?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 22, 2011 | Whirlpool RBS275PD Electric Single Oven
I have a ZDF20X double oven and the main bottom oven is not heating, The fan and light are working but it is not heating. HOw do I repair this - is it an element and how do i replace ? Thanks v much.
Most likely it is a faulty oven heating element.
You will need to replace the element.
Usually the element is a circular shape which is situated near the fan, normally you will need to remove the back of the oven, Switch off the power at the wall first, locate the element and remove the fixing screws and electrical connections then fit the new element and reconnect.
Only attempt this replacement if you are confident to do so and have a basic electrical and mechanical knowledge.
Dec 11, 2010 | Zanussi ZDF490 Electric Double Oven
I have a whirlpool oven Model G2P61F/01SR/WH AND IT DOES NOT HEAT UP. i AM GUESSING ITS THE ELEMENT IS OPEN CIRCUIT BUT CANNOT FIND A SCHEMATIC TO LOCATE IT AND CHECK. CAN YOU TELL ME WHERE THE ELEMENT IS...
If it is an electric fan assisted oven, then the element will be located at the rear of the oven compartment, behind a removeable cover.
Hope this helps you.
Jan 09, 2010 | Ovens
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
Oven not heating up but fan and light on
oven not heating up but light coming on fan working and grill working . it allso heats up on other settings but not enough to cook
Jul 04, 2008 | Baumatic B187 Stainless Steel Electric...
Baumatic bt180 oven
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element. if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
Apr 09, 2007 | Baumatic B180 Electric Single Oven
Main oven not heating up
fan oven element has gone. it is a circular element and is located behind the back panel of the oven. some elements can be removed with the oven in place but for many you have to take the oven out and take off the rear casing. whichever, it is not a difficult job. element cost about £30
Mar 29, 2007 | Electrolux EOU5330X Ultrafan Electric...
Amana AOCS3040SS Electric Single Oven Logo
353 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Joseph Hoffmann
Are you an Amana Oven Expert? Answer questions, earn points and help others
