Question about Emerson Televison & Video
Buffering problems thru vudu wireless
Signal strength is weak, showing only 1 line. All other devices are receiving full strength signal.
3 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: cannot record thru line 1
If you could but now you cannot then this is a circuit break down- although check your set up , but I feel it is the machine beginning to die
Posted on Jul 31, 2007
SOURCE: Panasonic DMR-EX75 has stopped receiving digital signal
Panasonic DMR-EX75 has stoped receiving digital signa
Posted on Dec 24, 2010
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Poor signal with WiFi on my zeepad
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
My WRT54G2V1 is now producing a poor or weak signal to the 20nd computer. I have reset it and poeered it down a couple times
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 24, 2012 | Linksys Computers & Internet
Weak signal on pci card
The signal strength for wireless devices depends on a number of factors including:
The distance from the wireless router / access point or gateway.
The objects in the path of the direct line of sight signal, i.e. types and thickness of walls, metal objects such as kitchen appliances etc.
The directional characteristics of the aerial on the router / access point.
The physical position of the router, i.e. is is low down or high up in the room - the best position would normally be at a height which gives the best / clearest footprint for the wireless signal.
Do you have other wireless devices - what is the signal strength like for those when positioned close to the device with the Ralink PCI card?
How many wireless provider devices do you have, i.e. do you just have the one wireless router / access point or have you extended your wireless network using a second router or access point to give greater coverage?
Are there other competing wireless networks close to your own network, if so, you may need to consider setting a different channel than the default channel 11 that many devices use.
Also try to keep your computer wireless devices away from other devices such as wireless telephones, wireless remote controls etc.
Note: the slot used to host the PCI wireless card is unlikely to make any difference as the physical location of the aerial is only minimally changed by a couple of centimetres. Try rotating the computer case so that the aerial is directly facing the wireless router (to remove the case as another cause of weakening the signal being received).
Dec 31, 2011 | Computers & Internet
My hcl laptop with winxp shows very weak wireless signal strength at just 2 metre from the modem though other devices show complete signal strength. the device manager shows no problems with the hardware....
You can try this solution
  1. Right-click on the 'My Computer' icon on your computer and choose 'Properties'.
  2. Click on the 'Hardware' tab and then click on the 'Device Manager'.
  3. Now, find the 'Network Adapters' section and click on the little plus-sign to the left.
  4. Find your wireless network adapter and right-click on it and choose 'Properties'.
  5. This is where things will get different depending on the brand of your laptop and wireless card and which drivers you have installed. Browse through the different tabs and look for settings such as 'Power Management' or 'Transmit Power'. Adjust the settings to either disable the power management or increase the amount of power used by the network card.
  6. Now, test your wireless signal strength to see if you still have the same weak wireless signal you had before. The chances are that you will notice an increased wireless signal strength.
Jan 17, 2011 | Computers & Internet
I recently purchased a xbox 360 wireless N network adaptor for the xbox 360. The router for my home network is a Linksys wrt160n. Problem 1- weak signal. the xbox is on the same floor less than 50 ft away...
btwork
In regards to your weak signal count how many walls are actually between the router and your XBOX because this can effect your signal strength. You may need to move the router into a more open area.
As for the network adapter running in G mode and not N mode if you have any G wireless devices connecting to the network this will bring the router down to G mode. So ether you will have to run a G mode or upgrade your other devices to an N network card. Another option would be to get another router or access point to set one closer to you XBOX to get a better signal.
In regard to accessing your video and music files on your computer you do not have to open a port your firewall but set the XBOX as approved device. If you go to this link it will help you get your system setup properly.
http://www.xbox.com/en-US/pcsetup/
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Dec 24, 2010 | Computers & Internet
ADAPTER not working
Check the distance bet computer and the Router.
Donot keep your router near television, microwaveoven or any radio active devces, it may reduce the performance.
Check the Antena terminals for any loose connections.
If possible check your wireless signal strength with another Laptop, to diagnose the router is working fine.
If everything seems to be fine, it maybe the issue with the Adapter.
Goog Luck
Feb 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Linksys WRT54GX4 loses internet connection
Not a problem, you have to consider maybe other devices and or networks competing/interferring with your network. If you know how to enter the Linksys router menu I would 1. change the frequency the router operates on 2. change the channel the router will use 3. change the default password to something else besides the default.
All of the settings for your router out of the box are at default, wonder how many other people are running the same thing in your neighborhood? I always change from the default, you may also be receiving interference from devices using the same freq/channel as your router. Changing these will eliminate those possibilities.
Don't forget to encrypt your network, that is most important.
Jul 15, 2009 | Linksys WRT54GX4 WIRELESS 802.11G...
I can't make calls from my Blackberry 7290
Check on the right hand corner of your device for the vertical signal bars - 5 bars indicate full strength and 1 indicate very low signal. "OFF" indicates the radio is off and need to be turned on.
In case signal strength is good, you should be able to make and receive calls. In case it does not work, just try taking the battery out and put it back after 15 seconds and try again.
In case signal strength is low , either you are in a low signal zone or your SIM card is bad. Take the SIM card out, wipe the gold plated surface using a clean tissue, put it back and try again.
In case the radio is OFF, turn it on by clicking on the icon (Turn Wireless on) on the home page.
Dec 27, 2008 | RIM BlackBerry 7290
Wireless signal is very weak
Signal strength is varies depend on your position,
Hardware type, wireless provider line-of-sight (how
many obstacles that blocking the signal), and other
factors.
Make sure you connect to the same wireless spot.
Or at least go to places with wireless spots and compare
signal strength.
If you never have a strong signal from at least 5 different spots
(make sure you check it's the top 5 best spots you find,
ask others who connect to the spot also to make sure)
then you go to your repair shop and ask them why.
But, if you at least have 1 strong signal then
your spot just having a weak transmission.
Dec 26, 2008 | Dell Inspiron 2200 Notebook
Televison & Video Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
