Question about Compaq Presario C700T Notebook
No sound laptop fell from my hands.... but there is no problem with the software... but i am not able to hear the sounds... i think problem with the hardware part..... wat can i do for that... if it is a hardware problem should i dismantle my laptop... then plz give me the details regarding that also
My laptop has a dragging sound when I play music both from youtube and within the disk.The laptop plays well but at some point the sound scratches.Also i hear a different sound often from the back of
Dear Friend,
I think you have to Re-install driver of sound chip or media player may be your internal music setting is not set properly please check also before uninstall driver or software.
Mar 31, 2014 | Dell Computers & Internet
I installed a software called Hear on my T420 laptop after a while i uninstalled it but since then i have problem with sound! when i play music i hear the sound from the speakers, it's normal but
Use the SYSTEM RESTORE utility to go back to a certain date that you think is in its perfect condition, say 2 to 5 days ago will do. Everything will be restored except data or work files. Good luck
May 19, 2012 | Lenovo ThinkPad T420 Notebook
The sound on my dell latitude d600 laptop stop working completely after the speakers i had pluged in fell and broke. now i cant get sound from the laptop at all. could something be fried? how do i fix?
i would think it is more to do with the sound settings on the laptop rather than some thing been fried. You will have to go into the control pannel and go to the sould settings, have a play around with all the setting and i would be hopeful that you will be hearing things again soon.
May 20, 2010 | Dell Latitude D600 Notebook
Sound
It rarely happens but as you are saying that your laptop fell off. This can happen. It is a sound card failure may be due to a broken connection.
I think you will need to take it to a computer technician.
Hope this helps.
Apr 11, 2010 | Toshiba Tecra 9100 Notebook
When i put my hand over the mircophone it makes a sqeeking noise and when i try use adcuity to do my lrics it says error check input
1. The sound that you are hearing when you put your hand over the microphone is just feedback. Try adjusting the microphone input volume down a little and this should help reduce or eliminate this feedback sound. The reason that it happens is because by putting your hand over the microphone, you arr changing the characteristics of the mic's picup as toyr hand helps with reverberation and echo, both of which increase the chance of feedback.
2. I am afraid i don't know the software called adcuity. Please could you let me know the software author and which version it is and i will try to help.
Thanks
Mar 18, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba A45 laptop fell from table to floor
It sounds like your screen is damaged.Look on Ebay and get the replacement..If you have no knowledge of how to do it then I would suggest a new laptop.
Jun 11, 2009 | Toshiba Satellite A45-S250 Notebook
Sound problem with my computer speakers.
if u r not hear from your speaker . i think your laptop sound driver is not working properly pls chek your sound driver then u chek speaker ok . I think there r meany problem come to sound driver ok.
Mar 21, 2009 | Toshiba Satellite A65-S126 Notebook
No sound from speakers
Check your sound settings and recording settings once and check if compac has given any sound softwares and modify the settings in that by the way you can get i think..
Thanks
Mohan
Oct 29, 2008 | HP Compaq Presario V2000 Notebook
No sound from my acer lap top
i think the problem is that you need to update the sound card driver
Jul 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Gavindu gave a solution fro my toshiba laptop problem but...
Goto www.driverguide.com and create a username and password then search for the sound drivers for your system. download and install. enjoy.
Nov 08, 2007 | Computers & Internet
Compaq Presario C700T Notebook Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
