Question about Fisher and Paykel Washing Machines
Fisher and Paykel MW 512 stopping at rinse cycle
Machine goes through wash cycle and starts to drain before the rinse cycle then stops. A small amount of water remains in the drum and and there is a faint smell of smoke.
    Master:
  • Fisher and P... Master
  • 703 Answers
You have a faulty pump do not use until you replace it
Posted on Apr 21, 2018
5 Suggested Answers
SOURCE:
garing
  • 998 Answers
SOURCE: FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Posted on Aug 06, 2009
  • 3 Answers
SOURCE: Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Posted on Sep 19, 2010
  • 57 Answers
SOURCE: my washing machine fisher and
You have a restriction in your drain line or pump. Also you could have a pump going out. It will smell like a bad motor. So check for a restriction first.
Posted on Dec 02, 2010
Testimonial: "thanks, there's no restriction with the pipe, it probably is the pump. When puming water out, it's making a noise now.Can do sml loads tho!"
tunde007
  • 2382 Answers
SOURCE: I have a top loading
Hi, i fixed a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing (joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove). Now it Works.
First remove the keypad wires to the control board, then remove the screw holding the control board to the frame. The switch is underneath [to the right] of the control board. Looking at the switch you will have 2 wires to it, [it is just a normal microswitch]. now be careful on this next part, remove the switch from where it is clipped in. Remove the 2 wires to it. Does it look corroded?. See the little button on it, push it. Is it clicking positivity? Have you got an electrical test meter? You need to test for conductivity between the 2 contacts that the wires were on. if u have no conductivity then that is the problem.
Posted on Dec 13, 2010
My Elba washing machine, when reaches the rinse cycle, water is very loud, never before, but it never stops adding water. Water is draining fine but water does not stop to cycle to rinse.
The water inlet solenoid valve is being held open. Take off the hose and look in the opening to see if you can find anything. Otherwise replace that solenoid valve.
Sep 02, 2016 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
My washing machine fisher and paykel MW 511 will wash fine but when it gets to the rinse cycle it stops. The lights remain the same (no flashing or beeping) and the motor smells hot. It starts again after...
Nov 02, 2010 | Washing Machines
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Machine starts to fill then stops and beeps
try it on rinse cycle if goes ok then the hot water valve is faulty
Dec 14, 2009 | Fisher and Paykel Fisher & Paykel Washer
Aug 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
134 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
