DAEWOO DWD1210S WASHING MACHINE NOT WORKING ON SPIN CYCLE
This machine will not work properly through a wash cycle, namely the spin cycle. Yesterday, it got stuck at 11 minutes to go for around 30 minutes. I believe there is an electronic component that needs replacing but am not that technically minded. It also comes up with the UE error code which means clothes collected on one side or machine on uneven floor, but has not been either case when I've checked. Actually ran the quick wash cycle empty and it still came up with the UE code. The drive belt is in perfect order and the pump is new. The machine is only about 19 mths old and I've been loading it according the the manual guidelines since new. Please help, I can't afford another machine or a technician and would prefer to attempt to fix it myself.
Family of 5 needing drier clothes. Thank you in anticipation.
  • 15,935 Answers
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Zanussi aquacycle 1200.After a wash has finished and i empty washing, reload again,it wont start and none of the lights come on.eventially it works ok again after a good 5-10 mins.
you have probably done no harm. try selecting spin and drain again to ensure the water has drained properly.
Machine starting on its own after 5 minutes or so is usually the door lock failing, again not caused by your actions.
Sep 05, 2016 | Zanussi Washing Machines
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
My Daewoo does not want to spin, any suggestions?
first does all of the water pump out when wash cycle is done? if not then check your drain lines and see if pump is coming on. if it is not then it wont let the washer spin,
Jun 03, 2014 | Daewoo Washing Machines
My Bosch machine is not spinning properly leaving my washing still really wet. Tried cleaning pump once before and it worked but it's not worked this time round. At 1200rpm the cycle is really s
Bosch machine is not spinning properly leaving my washing still really wet This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jun 21, 2012 | Washing Machines
My washing fills and drains properly, but will not agitate or run the spin cycle. I sounds like it is going through the cycle properly, but will not turn the drum (spin cycle) or agitator.
Try picking a different wash cycle, instead of your annual quick wash cycle opt for the longer wash cycle and then you may find that the spin cycle may kick-in, hope this works for you, good luck!
Apr 17, 2011 | GE WBSR3140DW Top Load Washer
Daewoo nano silver dwf-170mp
This Daewoo top load washing
Machine is the worst washing machine ever. Tried to call their maintenance many times still the problems coming back. Water flowing non stop, i need to spin it first to work properly. They repair it but the problem coming back always and its not abyer yet. My advice dont ever buy this machine again.. Its a full waste of money
Oct 17, 2010 | Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Kenmore 110 Heavy Duty 70 Series Washing Machine won't spin
Can you move the basket by hand...if so you need a basket drive. If not you have a bad clutch or gear case
Jun 07, 2017 | Kenmore 24032\24036 Top Load Washer
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
971 people viewed this question
Top Washing Machines Experts
