Question about Sony KP-51WS500 51" Rear Projection Television
No Green Color only Red and Blue
The TV picture is clear and crisp but has No Green colors. Bright Reds and Blues. I am thinking I simply need to replace a Green Bulb but I have searched all over the Web for such a thing and have come up empty. Perhaps there is another problem.
I am not a repair person....but I am trying to fix the TV without spending a lot of money.
  • jim_hood Jan 18, 2009
    I understand from a previous solution the problemis...
    its the convergence problem.u need to replace the 2 stk ics on the main board to solve this problem.ic number 392.
    I need more such as Where to find such a part. I have searched the web and came up with nothing
    I have 2 different solutions to my posted problem. Which is correct?
    Genius:
  • 1,913 Answers
Reset all settings to facvtory defaults.
check all power cable and other connection.
aslo check resolution
Posted on Jan 18, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Let's try the basics. A Sony KP-51WS500 uses 3 tubes to project the three color, red, blue and green. From the video signal source, it passes through a signal processor that splits the signals into these 3 component colors to finally it drives its individual/respective tube.
Based on the above, considerations and/or checks that could be performed:
  • is the missing green consistent on all video sources, TV Tuner (receiver), DVD player, VCR;
  • if yes, it confirms that is indeed the TV;
  • if not, then possible connection/connector problem;
  • if it is the TV, primary suspect would be the green tube. Each tube has a heater/filament, this has to be checked;
  • additionally, at the rear of each tube is a squarish PCB (printed circuit board most likely marked CG) that contains drive transistors and discrete components necessary for the operation of the tube. If any component is faulty, it would also cause no green drive;
  • the green PCB (as well as the red's and the blue's) would all get their signals from a video board (mostly marked E (Y/C/J);
  • as can be seen above, it would need checks and diagnosis.
This of course would require opening the unit, perform voltage measurements, determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual (RA6 chassis) or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Should the green tube be deemed faulty, replacements/rebuilding maybe available from here or here.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
    Brigadier General:
  • 8,619 Answers
  • Rylee Smith
    Rylee Smith Jan 18, 2009
    You are right the stk's are what is causing the set not to come on. If you do not put heatsink compound on the back of each stk they run hot and will last under a year. Replace both and use heatsink compound and this should fix the problem.
    let me know if you need more info?
    Sergeant:
    Scholar:
  • 199 Answers
Click the link below for required parts: http://www.partstore.com/
enter the name of the model number and the required part and click on search on the link above.
    Genius:
  • 2,920 Answers
Go to a used tv repair shop and ask them to order it for you or call them and have them order the tube for you. alot of people dont know but a used tv shop is the best place to order the bulbs from.
  • 333 Answers
Behind the television you need to open the television to see if the green color gun is working. If it is not I suggest that a repairman do the task because it needs to be aligned. Also if the technician does it you will have a warranty. First you have to decide if repairing it is worth it because if 1 color gun goes then you can bet that another one will go soon after. These color guns are not cheap. If might be beneficial to buy another tv depending on hold old this unit is. I hope this helps.
    Scholar:
  • 160 Answers
Its the convergence problem.u need to replace the 2 stk ics on the main board to solve this problem.ic number 392.
What do I need to test on this TV?
Normally a shop would use a meter designed to test picture tubes--they would know in 2 minutes if the tube is bad here.
The A board would not cause this issue.
Listen carefully:
Another way to know if the tube is BAD: on the socket (pc board plugs to end of picture tube neck) among the other pins (should be marked) are red k, blue k, and green k---they go directly on that board to the video outputs----what we do is with a 10k ohm (10,000 ohm resistor) connected to a jumper wire with a clip on one end hook one end(clip) to the metal grounding strap with the springs and touch the end with the resistor connected to it to each K in sequence.
Take care as some dangerous voltages are there--when touched to red k screen should turn bright red, same with green and blue done one at a time.
If you get equal bright red, green, and blues the tube is ok---if one very faint tube is bad.
If all are bright (JUST TOUCH THE CONNECTED RESISTOR FOR A SECOND) THE problem is likely on that board---those K's go back either to an IC for each or one large IC (3 is more common) or to individual 3 pin transistors.
To try to narrow it to one transistor or one ic: unsolder one and remove it---do them one at a time and if picture suddenly looks near norm but now missing one color that is the bad part.
Ask first if questions BEFORE YOU DO THIS.
Mar 22, 2012 | Sony KV-36FS13 TV
Sony Wega model kv-32fs120. Color is all reds and blues, no greens or yellows. We have tried adjusting the hue as per the owner's manual and also the re-set but nothing changes.
The color of the television are compose of three color RED,GREEN and BLUE.So the lost color is the green.The problem is in the color section of the CRT board in the chroma section and in the CRT socket board.Maybe theres a loose connection in the PCB like the cathode output transistor.
Sep 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When I use my bluray player, the colors are all reversed. Reds are blues and blues are reds. Do I have a cable connected wrong?
If your using component input, then yes you do. Make sure all colors Red, Grn and Blue match from the Player to the Component Input. They all have 3 color codes.
Feb 04, 2011 | Televison & Video
My tv is showing blue when i turn it on i think my blue projector light is out?
i have a mitsubishi vs-60111 when i watch the tv as of last week the color is pale like green color or green,gray color the picture is sharp yet , i took front cover off the lights are still bright red , green and blue what can be the problem / joe
Nov 06, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Picture is pale, yet reds are bright. checked color, brightness, and conversion settings. TV seems unresponsive to the color, tint, and brightness adjustments.
open the back and look into the projectors red blue and green should be clear picture if its blurry need to change the coolant if its not on need to replace the projectors
Aug 22, 2009 | Philips 50P8341 50" Rear Projection...
COLOR PROBLEM
you have a miss aligned convergence. try to aligned it first.
Aug 06, 2009 | Philips 55PP9363 55" Rear Projection...
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
Color distortion issues
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Oct 07, 2007 | Sony Grand WEGA KDP-65WS550 65" Rear...
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Sony KP-51WS500 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
