Question about Whirlpool LER5636P Electric Dryer
Runs but does not heat
The dryer will run constant, with no heat and will not shut off..
    President:
  • 1,214 Answers
Sounds like the timer may have failed if the dryer continues to run for hours and hours. And this may be what keeps the heating elemnts from coming on.
Reply your findings and I can help you more.
Posted on Jan 19, 2009
GE dryer runs but only heats on timed cycle not the other 2 cycles.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Feb 17, 2015 | GE Dryers
My danby dryer keeps shutting off and turning on and the clothes take forever to dry
GOD IS STILL GOOD !!!!
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Sep 09, 2014 | Danby DCD5505W Electric Dryer
What is wrong with my gas dryer ? no heat and wn't shut off.
FIRST OFF IN THE AUTO DRY MODE THE DRYER USES THE MOISTER SENSOR AND AS LONG AS THE MOISTER SENSOR DOES NOT DETECT HEAT OR DRIED CLOTHES IT WILL CONTINUE TO RUN FOREVER.
NEXT AS FOR UR NO HEAT:
Aug 09, 2014 | Kenmore Dryers
Dryer running, but not heat
May 05, 2014 | Frigidaire Electric Dryer
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Dryer shuts off after about 5-10 minutes of running. The top of the dryer is hot.
Howdy: There is a thermostat inside the unit in the back. If this has lint clinging to it, it will shut off unit. Also the firing ignitor has two soleniods
that stick and turns off unit too early. But with the top of dryer hot I would say the heat always stays on and the thermostat shuts off ignitor. The firing should be a pulse type heat, not a constant heat. Good luck - Doug
Dec 08, 2009 | Kenmore Dryers
Whirpool Dryer Heating and timer issue
YOU NEED CHEK:
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Oct 05, 2009 | Dryers
Fridgidaire Dryer runs constantly when plugged in
It has to do with the onboard timer or timer board
Feb 13, 2009 | Frigidaire FGQ1442ES Gas Dryer
Electric dryer - drum turns but no heat
If it has a conventional electro/mechaniacal timer, then the timer is faulty, as it should advance, unless of course it has a time delay function, if it has, make sure it is off.
This probably explains why it is not heating.
Plz rate this solution.Thanks.
Dec 26, 2008 | Dryers
Dryer doesn't heat and runs constantly
depending on the model; if the timer is in the automatic cycle it will not advance if there is no heat, it must heat in order to satisfy a thermostat to tell the timer to advance this is what makes it automatic. If the timer gets to the end of the timed cycle and will not advance to off, sounds like a bad resistor connected to the timer, I would first check the heat circuit to find out why its not heating. Dont mean to complicate, but everything in the dryer has something to do with heating, element,thermostats, temp switch, timer and even the motor. Check for burnt wires at the terminal block for the cord. hope this helps.....
Nov 19, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
169 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
