Question about Lenovo ThinkPad T61 Notebook
Whenever i turn on my t61, it will automatically die after 2 mins so i decided to replace the battery. but then after charging the new battery for 12 hrs, same thing still happened. what would be the cause for this? Thank you
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Could be a million things! Process of elimination is the only way.
The fan might be blocked and causing it to overheat and cut out.
CPU might have a crack in it from overheating.
Memory or motherboard might have a crack in it from overheating.
As the PC warms up the crack expands until something doesn't connect.
Bad connection on battery terminals
Power supply fault
Good luck
Posted on Dec 31, 2012
Battery completely drained after 45 mins of listening to cd player without car running,
a healthy battery will take a charge and discharge and be o k -you have several things going on-the ticking noise is some kinda rely that is turning on and off probably because of low voltage-the voltage jumping around sound like the alternator is giving up and is not fully charging battery-you may also have a drain on the battery that doesn't stop when you turn the key off like an extra power amp for the radio- you can take your car to autozone or advanced auto and they will check out the charging system for free and tell you what is going on-cheers Denny
Nov 23, 2013 | Cadillac DeVille Cars & Trucks
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
How can I check my alternator on my 1999 Ford Ranger. The Ranger died on the side of the road today, and all that showed was to check the battery prior for about 10 minutes.
well...whenever the battery light comes on in a vehicle its almost always a charging problem,i would suggest replacing the alternator and charging the battery before starting it,alternators were meant to keep a battery charged NOT charge a battery, hope this helps
Oct 12, 2010 | 1999 Ford Ranger SuperCab
My phone is completly charged and when i pull it off charge about half an hour after depending on how much i use it, it turns itself off and then when i try turning it back on the Lg start up comes on then...
The happy news is there is no problem with phone,the hardware of your phone is in good condition.The problem is the battery.The battery of the phone is dead.This a step behind Stone dead stage.Next state of your battery is stone dead.You can't even use it more.Now the phone Battery will act like charging.Your battery can take small amount charge only because it is dead..Even though you charge your battery for 2 days continuously it will stay for 30 min or 10 min depending the charge usage.
Solution for this is you have to replace it soon..Go to nearest shop and check this with their battery and buy it.
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | LG KU990 Viewty
Lenovo T61 Battery life 10 min? Any advise?
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Nov 09, 2009 | Lenovo ThinkPad T61 Notebook
Replaced stator, brand new battery, died after 10k ride
sounds if regulator is not working or poor connections within charging circuit
Jul 04, 2009 | 1995 Suzuki VS 800 Intruder
My K800i battery dies very quick
Dear Friend,
                 U are saying that u have bought this mobile 2 yrs back so check wither ur battery has been expired and change it.Otherwise switch off ur mobile and put it in charge and check it out the normal standby for any mobile is 2 to 3 hrs.Kindly check it and revert back
Regards,
Aysaam
May 06, 2009 | Sony Ericsson K800i Cellular Phone
The phone will only turn on when it is charging!! :(
hi i have the xact problem with mine but i found out it is the battery i would charge it and it will say charge complete and i will only get mayb 2 txts and a phone call b4 it shuts off on me. try a new battery ans see what happens
Jan 16, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Battery charging
Does the machine boot and work just on AC?
If it does then you may have a bad battery - Does the old battery charge?
If it does not work on AC then try another AC adapter - even the generic universal kits should be enough to test it.
hopefully that's all thats wrong. let us know.
Dec 27, 2007 | HP Pavilion dv4000 Notebook
Shutter lens won't go in
If I remember right it takes AA batteries. Correct? Perhaps one of your NiMH AA's is not charged properly. Try it again with two newly charged NiMH batteries. You might also try putting in two newly charged batteries and let it sit for 24 hours and then turn it on. Lastly you might try putting a little pressure on the lens when you turn the power on. I had to do this once with my Optio S4. Hope you can get it figured out.
Sep 08, 2005 | Pentax Optio S40 Digital Camera
Lenovo ThinkPad T61 Notebook Logo
41 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
