Question about Kenmore 60172 Electric Commercial Dryer
Dryer doesnt work but i hear the timer working
My Kenroe dryer does not work. I hear the timer clicking but the dryer does nothing. I changed the Thermal Fuse and it worked fine 3 loads. However, it stopped again. I did notice the heat was twice what it normally is. Could this mpossibly be the Heating Element?Somthings making the heat increase and blowing the Thermal Fuse. Please Help!
  • cenosin May 11, 2010
    are your duct clean.this usually causes the thermal fuse to fail
  • 686 Answers
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Posted on Mar 04, 2009
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Whirlpool estate teds840jq2 dryer just stopped working. I can hear a clicking sound from the timer when the timer is turned to a setting but when I press the start button, nothing happens
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Estate TEDS840JQ Electric Dryer
Dryer will not start
if you are sure that your door switch is ok than you have a bad motor
but double check the door switch  the door switch has two wires take them off and connect them together if that makes the dryer work its a bad doorswitch if it doesnt help you have a bad motor
Jun 07, 2009 | Roper RES7648E Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Whirlpool Dryer
NEED A NEW TIMER NOTHING YOU CAN DO ABOUT THAT
STEVE'S APPLIANCE
516-300-3249
Apr 06, 2009 | Whirlpool LER5636P Electric Dryer
Dryer won't start.
possibly the starter/hold relay or the timer itself. ensure the door is shut properly aswell.
Mar 13, 2009 | Dryers
My maytag dryer doesnt work
hi thanks for the question i would check the power coming into the dryer a fuse couldbave blown
Sep 09, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Kenmore 60172 Electric Commercial Dryer Logo
326 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
