Question about HP LaserJet 1022 Printer
Trying to install a print hp 1022 to my laptop which uses vista
Gone through the printer wizard and it says instalation error spooler not working can you help please
    Genius:
  • 2,120 Answers
Go www.hp.com and let the website auto-detect your printer and download the drivers automatically.
Posted on Jan 18, 2009
My HP LaserJet 1022 is not responding even after I click print. It happens just now. Yesterday morning was fine. Keeps the document in pending and when I try to cancel or click print it says the print...
This seems to be a problem on these printers. I have five of them on my network and I had to use a generic driver to make them stop shutting off the print spooler on my print server. I use the LaserJet III driver which is a good HP generic driver. I found it to be best to uninstall all of the 1022 software and install the printer using the above driver that is part of the windows operation system therefore there is no need to download one.
Apr 10, 2010 | HP LaserJet 1022 Printer
The printing spooler service is not running.
Go to the control panel. Select printers and right click on your printer. Select properties and turn print spooling on.
Aug 08, 2009 | HP Hewlett Packard LaserJet 1022 Printer
Lj 1012 or 1022 hangs the print spooler
Since you're mentioning policies, you've probably got a bit more background than most.
Check your update histories. You're looking for the same correction/time-factor with both XP/Vista.
Verify the driver version. Download the newest driver. Try it on one machine. Try the previous one.
Look at other printer drivers installed. Multifunction printers are the worst for conflicts and hogging resources.
May 14, 2009 | HP LaserJet 1010 Printer
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
May 08, 2009 | Sony Office Equipment & Supplies
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
Nov 23, 2008 | HP PSC 1610v All-in-One Printer
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at dabesderis06@gmail.com
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn’t work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click “Print Spooler”. Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you’re lucky, this might be all you have to do. Still doesn’t work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer’s software from the manufacturer and reinstall it. get more information for printer spooler error .Hope this helps you.
Mar 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Spooler crashes when printing random PDF's
Installing new drivers dind't help. But what I did is I checked print as an image from within pring options in Adobe Acrobat (you gotta go to "advanced" to find that check box), and then it worked.
Feb 05, 2008 | HP LaserJet 1022 Printer
HP LaserJet 1022 Printer Logo
105 people viewed this question
Seeker5211
Seeker5211
