Question about Lands Phones
I have a vonage phone model L603M and both handsets say aout of range everything is plugged correctly
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: GE handset 28101 will not sync with base-GE 28129
Unplug power cord from the base for ten or fifteen minutes, this is the only user level operation that you can do to try fixing the problem.
If after resetting the base still do not find the handset, then either the base or the handset is faulty.
If the base works fine with a different handset, then it is the handset.
Posted on Sep 14, 2008
  • 44 Answers
SOURCE: Vonage customer, problem running through home phone wiring
Make sure you have disconnected the original phone line at the first entry point to your home. Even though regular phone service is disconnected (software) the original phone line carries some "noise" which can cause issues when trying to utilize existing phone wiring throughout the home.
Posted on Dec 02, 2008
Why am i unable to connect to my motorola L603m and theres no power supply
Contact The point of purchase. The phone should come with a charger. Or you can contact Looking For Help to find a replacement.
Mark
Motorola Support
May 12, 2014 | Motorola Mobility L603m Digital Cordless...
How can I add a 4th handset to my Motorola L603M?
I think you all totally missed the question. The phone set comes with the base and 2 extensions. He is wanting to BUY a 3rd extension for this unit, if I am reading this correctly. I have the same phone set and I have not found anywhere that sells additional handsets. Sorry.
Nov 22, 2012 | Uniden Cordless Phone
My phone says out of range / fuera de rango no tone no incoming
My phones do the same thing, first you have to make you have the right handset for the correct base, when that is done recharge all the handsets on there respective bases and that should solve the problem..thx steve
Jun 20, 2009 | GE 21905FE1 Cordless Phone
Suddenly have voice mail messages on handset (beeping before dial tone) when hooked to external voice message machine. I am using Vonage as my company.Panasonic hands free hooked to 4 handsets. Model is...
vonage gives you a personal voicemail. You should contact them and find out how to retrieve it first. If you have your companys voicemail on the panasonic you should also make sure that vonage voicemail get longer waiting time.
Jun 15, 2009 | Panasonic KX-TG5621 Phone
Two phones in use with Motorola VT1005 result in very low volume
disconnect the POTS line incoming to your home on the outside of your house. This will make the phone wiring within the house a standalone network. Plug the Line 1 jack of your TA into any available phone jack and the remaining jacks in the house will be energized. This will create the same environment as you had with POTS.
Jun 07, 2009 | Panasonic KX-TG2740 Cordless Phone
No dial tone on headset 2
If you have a regular phone, then connect it directly to the Vonage phone router. Be sure and connect to the correct port on the router (mine has 2 ports, and I use both, but a single line subscriber would only hook to Line 1).
See if you get a dial tone with the standard phone hooked up (we are testing that the Vonage is good.first, then we'll deal with the Uniden phone.). If not, what do the light's indicate on the Vonage router? Have you subscribed to Vonage? Do you have a cable between your router and the Vonage router?
Reply back back what you find and I can help you more.
Jan 23, 2009 | Uniden 5.8GHz Cordless Phone
Phones won't work
A) Ok first try to disconnect everything and connect all the batteries and cable back. Charge your batteries to full. Then if it still Out of range, do this with all your handsets.
- Disconnect the battery
- Hold the * and # key on the Handset and put the battery back without releasing the buttons. (now your in test mode)
- press the 2 softkey below the screen ( it's a factory reset, erase everything)
- You will see RAM/EEprom erase on the screen
-After the bip press end
B) OK! Now disconnect the power adapter from your base unit .
-Hold the memory button on your base and plug the power adapter at the same time. Then the base will bip to let you know that you done it correctly.
-after the bip press No.1 ( that's mean the handset 1 is de-registrer.
- Now De-register all the other handset by doing the part B again. But only changer the No.1 for 2 then 3 then 4.
C) Disconnect and reconnect everything and use your manual to register your handsets with the base and your done! Everything should be ok !
Nov 21, 2007 | Uniden DCT648-3 Cordless Phone
Lands Phones Logo
115 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
