Question about Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN
Reolace light bulb in Minka aire Viper model number F807
  • 10865 Answers
SOURCE: Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Posted on Sep 07, 2009
  • 377 Answers
SOURCE: I have lost my instructions and cannot figure out
Hi Bill. So far I have not been able to find a manual, but I will keep looking. In the mean time, if you want to give it a try, it appears to me that the circular piece that has the fingers that hold the light globe is probably put in place to hold the globe by a "turning" motion. If you were to reach up and grab this ring and gently turn it counter clock wise I bet it would turn perhaps 1-3 inches and disengage the fan body. Makes sense that the manufacturer would make it easy to change light bulbs and viewing the fan, this would be about the easiest way to do it. I would assume the glass globe is NOT fastened to this ring in any manner, so if you do decide to try this, be ready to have the glass globe release from the holding ring.
I will let you know when/if I find a manual. If you decide to try my solution and are satisfied with it, I would appreciate a Thumbs Up rating from you. BTW, nice fan. Paul
Posted on Oct 08, 2010
Testimonial: "pwillitz was very helpful in suggesting what I needed to do and it worked; from now on I will not have the same problem in the future!"
SOURCE: Minka Aire Como F603 - Light bulb burned out
I found the Manual to the F603 in pdf format at: http://minkagroup.net/Admin/UploadFiles/F603-English.pdf It describes how to put bulbs in so it was simply a matter of reversing the instructions to get the old ones out. However, it is not that easy to get the bottom section off so one has to be careful or you will twist the whole unit instead of just the bottom part..... I think what you did was push up too hard and then turn the whole unit. Try pushing up firmly but at the same time hold some fingers (or have someone help in this) on top of the bowl above the fan blades and then twist counterclockwise an inch or two and the bottom part will release (don't let it fall). Then you have easy access to the bulbs. Good luck.
SOURCE: minka aire concept II ceiling fan bulb replacement
The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
Posted on Jan 23, 2011
snowghost1
  • 784 Answers
SOURCE: My Minka Aire conceptII ceiling
most well stocked hardware stores will carry bulbs that are larger then 100watts -- or a specialty lighting shop will also have a higher wattage bulbs.
c...
Posted on Feb 24, 2011
Change bulb on minka aire fan
Call Minka @ 1-800-307-3267
Nov 03, 2015 | Minka Aire Ceiling Fan
Minka aire viper ceiling fan bulb
1- 100 watt mini can halogen.
Sep 03, 2014 | Dryers
CHQ8BT9051T
Yes. Call Minka aire @ 1-800-307-3267
Jul 16, 2014 | Minka Aire Ceiling Fan
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
How do I change the fan blades on minka model F807
You're going to have to take the fan down & take the top cover off.
Mar 07, 2013 | Dryers
Sep 07, 2009 | Minka F603-WH Ceiling Fan
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN Logo
129 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
